Diff ????
Old Aug 8, 2003 | 11:36 AM
DODGE4X4's Avatar
Diff ????
I want to change the fluid in my rear diff today but, I am not sure wich diff I have: the 60,70 or 80. How can I find out. I have a 01-3/4 ton 4x4 with 3.54 gears. ???
Old Aug 8, 2003 | 11:56 AM
barracuda's Avatar
Re:Diff ????
it should be a 70 rear....60 front i don't beleive it comes any different w/ your style truck
Old Aug 8, 2003 | 12:21 PM
DODGE4X4's Avatar
Re:Diff ????
Thanks
Old Aug 8, 2003 | 01:05 PM
Mr. 45's Avatar
Re:Diff ????
60 for the front. 70 or 80 rear. If it is a automatic transmission it is a 70, If it's a manual it's a 80
Old Aug 9, 2003 | 02:47 AM
dodgeram's Avatar
Re:Diff ????
if I remember right from when I changed my fluid(60 front 80 rear) you need 7 quarts of fluid all together .......3 front........4 rear
Old Aug 9, 2003 | 09:10 AM
JMull's Avatar
Re:Diff ????
There is a decal inside the glove box on mine. Tells which rear is in the truck. I'm pretty sure that the older trucks had the decal under the hood. I'm sure you will have one, just have to find it. Should be a 60 up front, and a 70 if an auto, or an 80 if a stick on the rear.
John
Old Aug 9, 2003 | 10:36 AM
Barney's Avatar
Re:Diff ????
Lots of info here at Fritz's for axles and other things.
http://www.dodgeram.org/tech/specs/Ramspecs.htm
Just work your way down through the blue links until you get to the data page for your component. There will be lube capacities listed there too.
Usually underneath the hood, in the latch area, there is a build sheet for your truck. On it is the optional equipment. Your rear axle might be on it. If it has a limited slip option, that will also be listed. It might be a bit faded by now though.
Old Aug 10, 2003 | 10:31 PM
DODGE4X4's Avatar
Re:Diff ????
Thanks for all the help yall ;D I have a 60 front and 70 rear. ;D
Old Aug 11, 2003 | 01:10 PM
Mr. 45's Avatar
Re:Diff ????
Did you get it changed? What kind and weight of oil did you use???
Old Aug 11, 2003 | 02:15 PM
DODGE4X4's Avatar
Re:Diff ????
I used SAE 90, and 2 bottles of the Mopar modifier for my positrack.
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
BradN
Mar 13, 2003 07:32 AM
USMC64-70
Nov 10, 2002 02:59 PM
greatwhite
Nov 3, 2002 08:12 PM
