cummins power spec
Old Jan 25, 2004 | 01:36 AM
duner's Avatar
cummins power spec
just wondering if anyone has utilized the free power-spec software from the cummins website? i downloaded the software and it looks like it can flash the ecm to do all sorts of things with the proper adaptor.
Old Jan 25, 2004 | 12:55 PM
AKDSLDOG's Avatar
Re: cummins power spec
I will warn you now! We use this software and others at work for the big rigs, you can "turn on and off" alot of things in there, just remember before you mess around inside your "ECM" write down what it was in the begining, if you change things around and "forget" later what you did, you are SOL! There is some really cool info in there if you know what you are doing.
Old Jan 25, 2004 | 06:40 PM
duner's Avatar
thanks for the warning, and the response. you would't happen to know where the factory setting falls on the fuel economy/performance scale would you?
Old Jan 25, 2004 | 07:08 PM
billg's Avatar
Re: Re: cummins power spec
What kind of adapter do you use to to access the "ECM"? Where do you tap in?
Old Jan 25, 2004 | 07:12 PM
duner's Avatar
datalink II, the diagnostic port as far as i can tell
Old Jan 25, 2004 | 07:14 PM
dieseldrag's Avatar
Careful everyone, it is a read only unless you get a P/W for your computer from your local cummins distributor. It was released for parameter and gearing help on HD and MD trucks.
You would need a Inline adapter and cable set, and no, the 2003 and later have no com port. We at Cummins can't even talk to them... DRB only.
Do download a play with it, no harm done. I have not tried to use it for a B engine, as I use INSITE. www.powerspec.cummins.com is the site. Free.
Old Jan 26, 2004 | 02:50 AM
MCummings's Avatar
Also,, many things CAN'T be changed because we use only 50% of teh Cummins ECM. the Cummins ECM has 100Pins to control high idle, and lots of other awesome functions, but the 50Pin Dodge version ECM lets you access things like Engine Hours and Highest recorded RPM.
Good luck
Merrick
Old Jan 26, 2004 | 09:52 PM
duner's Avatar
only thing that really interested me was the max fuel economy/max performance feature. does anyone know if this feature is accessible?
Old Feb 18, 2004 | 07:09 AM
killfast1's Avatar
Does anyone know the pinout for the datacable?
Alaskanwheeler
Jan 29, 2006 10:49 PM
killfast1
Jun 9, 2004 04:42 PM
1stGenBikeHauler
Jan 25, 2003 12:31 PM
Mopar_Mudder
Dec 26, 2002 12:41 AM
