Cummins Parts ?
Old Jun 30, 2004 | 08:21 AM
Ohio Joe's Avatar
Cummins Parts ?
Long story short... Lift pump is headed south, the Dealer say's the flow is within spec Is there someplace online that I can purchase a lift pump? Also has anyone found out for sure if Dodge will still honor the warranty on the injection pump if you go with the RASP???
Old Jun 30, 2004 | 09:38 PM
nitrousn's Avatar
what is your pressure readings?
Old Jun 30, 2004 | 11:38 PM
Ohio Joe's Avatar
I am getting between 11-12 at idle, under full throttle I can pull it down to 2 and running down the highway it's about 10. I just changed the fuel filter not quite 5k ago, and I know the guage is correct because I have another small fp guage under the hood inline right before the sending unit for the in-cab guage.
Old Jul 1, 2004 | 12:03 AM
KATOOM's Avatar
Look for a Cummins store. Maybe they will send you one if they are to far away.
Old Jul 1, 2004 | 08:53 AM
nitrousn's Avatar
i run 12 to 13 at idle and at the most i can pull it down to 7 psi wide open. i also run in the 11 -12 at cruise speeds light throttle. i also passed the volume test. you might try a filter. i am reading mine pre filter . a filter would be a easy and cheap fix.
Old Jul 1, 2004 | 08:57 AM
nitrousn's Avatar
you might go here and contact a dealer. some have web sites that you can purchase parts.
http://www.cummins.com/service_locator/index2.cfm
nbaggett89
Dec 26, 2015 09:36 AM
Checkmate
Mar 2, 2008 05:55 PM
BRUISER
May 2, 2007 09:20 AM
CTD_Neil
Jul 19, 2005 08:13 PM
xj2extreme
Feb 20, 2003 10:38 PM
