Crank Position sensor can it be cleaned?
Old Dec 17, 2006 | 08:52 AM
Junk Man's Avatar
I stopped for lunch yesterday. When I started back up, the tach wouldn't move & the check engine light came on. The tach started after a couple of miles. I borrowed a sanner & pulled codes P0336 Crankshaft Position Sensor & P0234 Overboost condition. Parts stores can't get the CKP until Tuesday. I need to be on the road. Truck is stock & has 106000 on the odometer. Will cleaning the sensor fix the problem or do I have to replace? Will aftermarket work as well as OEM on this part? I'm trying to fix ASAP.
Old Dec 17, 2006 | 09:15 AM
01PPUMP's Avatar
I have never had good luck with cleaning them, when there bad there bad.
imbodie
18
Jan 15, 2013 02:22 PM
Blue600
Oct 4, 2004 07:20 AM
redhornet
Jun 17, 2004 01:02 AM
kingofdodge7131
May 24, 2004 01:09 PM
linetrash75
Jan 26, 2004 07:43 PM
