Crank but no start
Old Aug 4, 2015 | 05:25 PM
Kydieseltech's Avatar
Crank but no start
I have a new injection pump and fass on my truck after got together ran great started to let warm uo this morning and ran great got half way to work and died crank but no start got towed to work lift pump wasn't running so wired to ignition bled out lines and truck ran great for about 1/4 mile then died Crank but no start what am I missing
Old Aug 6, 2015 | 11:11 AM
KATOOM's Avatar
Sounds like you're having a problem with air in the fuel system. How much fuel is in the tank? Are you sure all the fuel line fittings are secured? Whats the fuel pressures too?
Old Aug 6, 2015 | 06:29 PM
Well I think i have a draw straw issue had just over 1/4 tank fuel put 10 gal in it bled lines been running without issue for 2 days now
Old Aug 7, 2015 | 08:07 AM
patdaly's Avatar
Either a draw straw issue or more probably a flaky fuel sender issue. Run it down to the almost running out point on the gauge and then fill her and see how close to 35 gallons you use......
Big Ronnie
Jun 19, 2015 08:03 PM
Stormin_Norman
Oct 2, 2010 07:47 PM
CoolumConst
Oct 11, 2008 10:00 PM
bsj04
Feb 18, 2008 06:06 PM
Gunrunner
0
Jun 13, 2007 11:26 PM
