Cracked Intake
Old Jun 16, 2009 | 10:43 PM
dodoguru's Avatar
Cracked Intake
I found a crack on the intake manifold between the #3 and #4 runners, I read in another post that in these turboed engines, the intake manifold is under pressure at ALL times and not vacum like a non turbo gas motor, is this true? Is this a common problem? if under pressure, that would explain the reason I had to accidently find it, the engine does not seem to lack any power and runs just fine, if anything a little low on boost in the intake, is that correct ?
What do you guys recomend, replace it with a bone-yard peice, weld it, or is there something aftermarket reasonably priced that is not out of this world.
Thanks
MF
Old Jun 17, 2009 | 07:27 AM
patdaly's Avatar
Weld it up, I assume you mean the Intake top plate? If you mean on the side, time for a head if you don't want to weld it up.
Old Jun 17, 2009 | 07:42 AM
jrs_dodge_diesel's Avatar
Correct, the manifold pressure is about equal to atmospheric pressure at idle and can build up to 22 PSI (stock engine) above atmoshperic pressure. That would create a boost leak, but not a major one. Unless the crack is wide.
If it is the manifold itself, it is made of aluminum and can be welded. If the head is cracked, that will need a lot more work to fix.
klx650a2
Apr 20, 2009 05:25 PM
BA05'CTD
Jan 7, 2007 03:08 PM
dodgezilla04
Jul 1, 2006 01:28 AM
Bobcat698
Sep 24, 2005 10:51 AM
WVPANHANDLER
Feb 1, 2003 08:23 PM
