Cold weather warm up
Old Nov 5, 2005 | 01:53 PM
jrs_dodge_diesel's Avatar
Originally Posted by ajpulley
When I used to drive an OTR Peterbilt, I wasn't supposed to idle at a low RPM, ever. It goes without saying that all of us idled when the truck wasn't moving: for A/C in the summer or heat in the winter. Sorry, the engine was a CAT 3406E, but the point is eveyone's engine idled in the winter. The cruise was set so you hit it and it idled up to 1,100 or so.
The point to this is idling up wasn't about warmth primarily, as it was to keep from developing "slobber" as it was called. Don't know what it was made out of, but it was like liquid and would spit out the stacks. That's why, as all the mechanics told me, not to idle at less than 1,000-1,200 RPM. Maybe worth investigating.
That is what is refered to as wet stacking. Its basically unburnt fuel from low combustion temps. It builds up on the valve stems too. To much of it can gunk up and bind the valve, never a good thing. This is why prolonged low idling can be a bad thing.
Old Nov 5, 2005 | 01:58 PM
ajpulley's Avatar
Thanks for letting me know. Can I assume it would happen to our little diesels too?
Old Nov 5, 2005 | 05:58 PM
Yep, it sure can.
Old Nov 6, 2005 | 01:26 PM
Dr. Evil's Avatar
Of course, and fuel washes past the rings and gets into the oil - NOT good....
Old Nov 6, 2005 | 01:43 PM
slim51015's Avatar
Originally Posted by Sea01Cummer
I fire mine upand wait a second till i got oil pressureand flip the brake on. I go back inside, fill my thermos, go feed the horses and by the time i get back to the truck and we are not talking 10 minutes either the heater is blowing warm air ant the temp is up from 140. Did i mention i love my exhaust brake.
Stevo
Yep ,same thing I do except I feed the dog. Exhaust brakes work great.
Old Nov 6, 2005 | 02:30 PM
j-dubya's Avatar
do 2000's have the high idle already in the ecm awaiting activation? also, whats yall's opinions on warming the truck in nt-so-cold temps as in above 0*? how long should i let it run before i go?
jeremy
Old Nov 6, 2005 | 05:15 PM
phox_mulder's Avatar
No, the ECM will need to be reflashed to a version that has the high idle, then it will need to be activated.
Late 2001's and 2002's are the only ones that came with the high idle ready for activation.
phox
Old Nov 7, 2005 | 09:46 AM
drew03's Avatar
A cheap way to raise your combustion temps and raise up the idle is to use a stick. Wedge it between the seat and the pedal. Works good.
redneck cruise control.
Old Nov 13, 2005 | 12:59 PM
Ph4tty's Avatar
I read in this forum that MAD ecm already has the high idle feature enabled
Two birds with one stone....
WilderMike
Feb 3, 2013 11:01 AM
herb
Jul 18, 2008 08:25 AM
Hydrauk
16
May 7, 2008 02:58 PM
leeboy
Mar 22, 2008 10:00 AM
buddha
Jul 31, 2005 07:21 PM
