codes.. voltage too low???
Old Jul 15, 2007 | 11:09 AM
24valver's Avatar
check engine light came on last night. Checked them out this morning and got these.
P0500-no vehicle speed sensor signal
P1693-companion code
P0237-Map sensor voltage too low
P0236-turbo/super charger boost sensor A circuit range/performance
P0122- Accelerator Pedal Position sensor signal voltage too low
On the P0500 my speed O is broke and i understand the P1693 kicks off of another code but don't know what i should do about the Last 3 codes. Has anybody had these same codes ever thrown and if so how you fixed them.
Old Jul 16, 2007 | 12:13 AM
REDNECK-WELDING's Avatar
i see you have the comp box..i do to thats whats giving the 0237..its in the wire
Old Jul 16, 2007 | 08:02 PM
24valver's Avatar
so you think maybe the comp box wire going to the map is no good??
Old Jul 16, 2007 | 10:37 PM
AggieJustin's Avatar
Actually, in my FSM, P0236 reads "MAP sensor too high too long" which would indicate reading higher than stock boost pressures. I'd clear those codes and pull the Comp box to see if they come back. Might be something wrong with the boost fooler in the Comp.
Old Jul 18, 2007 | 10:45 AM
i was refering to the 0237 one..this is the only code i am getting with my comp box..i pulled the chip out and had no problems..and now with the chip back in its back..my problem is in the comp wireing, but edge is being a bunch of ****** and not helping me
Old Jul 18, 2007 | 01:16 PM
jc248's Avatar
I'm having the same problem with my edge chip. I got the 0236 as well as I was getting a real rough idle, I mean bad. since turning it off no problems. Edge customer service sucks.
Old Jul 18, 2007 | 02:47 PM
24valver's Avatar
IM going to try pulling off my box this week and clearing the codes and see what will happen. Thanks a lot guys
Old Jul 18, 2007 | 02:51 PM
bnold's Avatar
APPS needs to be reset or adjusted
Old Jul 18, 2007 | 11:10 PM
daniel's Avatar
when 0237 came on in my truck it was because my comp had come loose at one of the fittings. my 0236 is on cause my map is unplugged but i have and 0500 but dont have any problems.
Old Jul 21, 2007 | 02:18 PM
24valver's Avatar
i just found a thread on how to reset the APPS. Im going to try it out hopefully it works out. the price on that APPS is scary i could get a manifold for that. Wish me luck
jaconst
37
Jun 12, 2014 10:02 PM
tinknocker827
13
Dec 4, 2013 06:26 PM
smokinram99
Feb 4, 2010 12:33 PM
Moobesor
Feb 23, 2008 09:57 AM
daveg
13
Feb 1, 2008 11:05 PM
