Codes not found in FAQ section!
Old May 30, 2007 | 03:37 PM
suprahalee's Avatar
The codes are as follows:
P1022
P0460
P1693
The truck seems to strumble in the mid trottle range, completely closed and completely open is runs fine. Does anybody know what codes these are!
Old May 30, 2007 | 03:41 PM
AggieJustin's Avatar
P0460 - Fuel Level Unit No Change Over Miles - when fuel level doesn't change for 40 miles
P1022 - Not in my FSM
P1693 - Companion code - gets set when you have another code set
Old May 30, 2007 | 04:42 PM
phox_mulder's Avatar
Could the 1022 be due to dyslexia?
P0122 Accelerator Pedal Position Sensor Signal Voltage Too Low
Fits with your description of the problem.
phox
Old May 30, 2007 | 07:04 PM
suprahalee's Avatar
What is the solution to this message?
Also does the TPS have a relay or is it fused?
Old May 30, 2007 | 08:17 PM
annabelle's Avatar
http://www.canobd2.com/support/DTC_lookup.asp
Old May 30, 2007 | 10:55 PM
Mopar1973man's Avatar
Here is the copy of the Codes from the Dodge FSM book...
http://www.idahobombersforum.com/tip...rror_codes.htm
Old May 30, 2007 | 11:28 PM
I'd try a recalibration of the APPS. You can find the procedure on here, just search for APPS recalibration. Or it may be that you have a bads APPS that needs to be replaced.
NoSparkplugs
Dec 15, 2009 07:53 AM
mbenedict
Jul 21, 2007 09:19 PM
bamataco1
21
Aug 30, 2006 09:45 PM
