Codes
Old Apr 29, 2009 | 09:08 AM
Hotcuda's Avatar
Codes
Hi guys I am sure theres a code break down in here some where I can't find it though. If some one could point the lost guy to it that would be great or if you could tell/ or send the codes to me in a pm also awesome. anyway here are the codes that just popped up I did replace both batteries the other day as the old ones packed it in to the point of shutting down everything in the truck when I went to start it.
P1693
ECU Codes
P1698
P1475
Old Apr 29, 2009 | 11:02 AM
HotRodTodd's Avatar
http://wiki.dieseltruckresource.com/wiki/Computer_codes
Old Apr 29, 2009 | 02:23 PM
Hotcuda's Avatar
Thanks Hotrod bad news none of my codes were there
Old Apr 29, 2009 | 04:05 PM
dodge2001's Avatar
ok...P1698---No CCD Messages Received From PCM
P1475---Aux. 5 Volt Output Too High
now i have no clue what the heck all that means, but that's what they say...
Old Apr 29, 2009 | 04:18 PM
Mike Holmen's Avatar
The Guru
Cuda, clear the codes and see how fast they come back in. Reading here that you might have a short and its reducing the voltage at the PCM. Check fuses first. Do you have a volt meter? Have you installed anything new into the wiring harness or had something apart recently? New stereo equip, if not installed correctly cause issues with ecm's and pcm's. Good luck, hopefully this helps. You could clear the codes, and its could be a weird occurance.
Old Apr 30, 2009 | 08:08 AM
Hotcuda's Avatar
Ok will unplug batteries for the day Sat have to run out of town anyway thanks the key doesn't seem to be letting me reset them hate to admit this but my wifes Grand Am had a button to reset the codes.
Old Apr 30, 2009 | 09:53 AM
The Guru
unpluggin the truck will not clear codes, anyways I never had any luck with. A code reader is the best way. dodge clears the memory after 50 starts/stops, so you could just turn the truck on/off 50 times. I will be back on the weekend, you could bring the truck over and we can take a look at it. I do have a superchip programmer, that clears codes. I live in Airdrie.
Old May 1, 2009 | 10:16 AM
Hotcuda's Avatar
Wow I thought 24 24hrs unplugged reset the whole system ok I will be back Sunday noonish if all goes to plan gf's bday weekend taken her to Banff, thanks Mike.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
