codes
Old Jun 7, 2008 | 08:51 AM
jivemother's Avatar
Question codes
ia geting these 2 codes what do they mean....p-0216 and p-1693
Old Jun 7, 2008 | 09:15 AM
brianpgriset's Avatar
They mean "Start Saving"
Sorry, they actually mean:
PO216 - Fuel injection pump timing failure - High fuel supply restriction, low fuel pressure or wrong or incorrectly installed pump keyway.
P1693 - DTC detected in companion modual - A fault has been generated in the companion control module.
Basically it means your probaby going to need a new VP44 or at least an IP. You getting any dead pedal?
Old Jun 7, 2008 | 09:20 AM
2RamsNoCash's Avatar
p0216 injection pump timing failure and 1693 companion code....sounds like another vp44 on its way to rebuilder.plenty of info on how to replace and diesel dan has a great how to series on you tube for the vp pump...while you are at it replace the lift pump..I would go with a fass and vp44 combo many online sell as kit and will save you a few bucks..
Old Jun 7, 2008 | 10:00 AM
ramlovingvet's Avatar
DTR'S Chaplain
Sorry to say it but welcome to the club!
Old Jun 7, 2008 | 10:51 AM
jivemother's Avatar
yes i have been geting the dead pedal , thought it was the quad box , i reset the apps today and it seems fine for now lol
Old Jun 7, 2008 | 02:24 PM
Honestly this is probably a temporary fix. I highly recommend getting a fuel pressure gage and seeing where your at, and how low it gets at WOT. There is a prayer you can save the VP but I wouldn't bet in it.
Above advice is right on, save your pennies and get a new VP and a FASS and forget about it.
Old Jun 7, 2008 | 05:39 PM
jivemother's Avatar
i put a new lift pump on about 6 months ago when i got the truck the original was dead but still running it must have put the VP to early grave lol
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
