Codes
Old May 16, 2007 | 10:18 AM
Goneputn's Avatar
Codes
I have a code that reads P PCU, anyone know what this means?
Old May 16, 2007 | 01:26 PM
Dr. Evil's Avatar
What method are you using to read the codes ?
Old May 16, 2007 | 03:42 PM
Goneputn's Avatar
The P PCU was what I got when I turned the ignition on and off 3 times on the odometer slot. My new code at the parts store was P0216.
Old May 16, 2007 | 05:34 PM
phox_mulder's Avatar
P PCU means the PCM is free of codes.
P 0216 in the ECM is bad news, usually means a new VP44 in your future.
phox
Old May 16, 2007 | 07:14 PM
Goneputn's Avatar
I took it to the dealer, they said it could be a throttle positioning sensor, transfer pump, or injecter pump. Didn't say anything about the trans. I only got 56 K on the truck. Trans fluid serviced, never burned the fluid. I don't know if that makes a difference or not. I have a feeling I'm about to get screwed. the P0216 code at the parts shop said PCN has determined that there is a discrepancy between the actual and the desired injector timing
Old May 17, 2007 | 03:12 AM
NoSeeUm's Avatar
Yeah sorry....
I think it generally means the timing distributor rotor is hanging up.
Jim
Old May 17, 2007 | 09:14 AM
Dr. Evil's Avatar
Dont be too suprised if you have to buy an Injector Pump. Hopefully not. Good luck.
Old May 17, 2007 | 09:38 PM
Goneputn's Avatar
Well, got the news today. It was the injector pump, service advisor recommended the I replace the transfer pump also. $3598.68 later I have my truck back and running like a champ. So much for all my upgrades I had planned. For everyone who isn't familiar with the fuel systems on diesels, have your pressures checked periodically. It will save you some cash.
Old May 17, 2007 | 10:49 PM
2500Ram's Avatar
Great googlie mooglie, that was alot of dough. For a VP and IN TANK PUMP
Old May 21, 2007 | 10:50 AM
suprahalee's Avatar
Monitoring the motor with a good set of gauges is a wise investment!
Fuel pressure gauge in your case would have pinpointed your problems.
Sorry about the dealer turning you over their knee. You need to learn to do the routine maintenance your self. And YES all pumps on ctd are routine.
Old May 21, 2007 | 11:25 AM
Dr. Evil's Avatar
What? Good God, you must be in Canada...wish you would have visited us before you had trouble - you could have gotten a new pump and bombproofed your fuel system for MUCH MUCH less than you spent.
Checking pressures periodically is not good enough. With a second gen 24V, you NEED a fuel pressure guage in the cab and need to be very vigilant in watching it.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
