Code P0234
Old Jul 19, 2008 | 09:55 AM
cm979's Avatar
Code P0234
Truck seems to have been lacking power ran a scan on it. It says P0234 Turbo Chargerover Boost Condition What does it mean. Is it anything to worrie about?
Old Jul 19, 2008 | 10:48 AM
OUTLAW44's Avatar
More Than Likely Its Ur Map Sensor.. Its Not That Hard To Replaced And It Shouldnt Be To Expensive.
Old Jul 20, 2008 | 02:36 AM
cody_d's Avatar
out of the Haynes repair manual. P0234: Engine overboost condition; turbo boost limit exceeded
Old Jul 20, 2008 | 09:22 AM
Ed ke6bnl's Avatar
Yes this is possible but we spent 2 days working on issues that can cause this problem, we where lucky that I had the same truck and swapped out the map sensor with no luck, cleaned all connections and check the entire boost system, checked the wastegate pressure and movement, turned out to be a bad Edge Ez. don't now if you have any type of chip but check it. That was our problem
Old Jul 20, 2008 | 09:57 AM
Blueboy's Avatar
Code
I had same code last week cleared it with
smarty, hasn't come back again.
delagem
Feb 27, 2008 05:32 PM
straight_six
Nov 15, 2007 05:37 PM
Redliner
Sep 12, 2007 06:31 PM
lovinCTD59
May 24, 2007 05:26 PM
ajg617
Jun 27, 2006 11:48 AM
