code p0216
Old Feb 17, 2006 | 03:46 PM
in2gpn's Avatar
code p0216
I just pulled a code P0216 and it tells me ing pump timing failure??? Vp44 gone or what the???? Runs fine and starts right up so i don't know what to think? Awesome FP necer get below 15 psi @ WOT. Any suggestions?
Chris
Old Feb 17, 2006 | 04:26 PM
Geico266's Avatar
Sorry to be the one to tell you, but the fat chicks are getting their revenge, your IP is on its way out.
Clear the codes and see if it comes back, kinda like dumping a fat chick.
Old Feb 17, 2006 | 05:19 PM
graphitecumnz's Avatar
No telling how long the doctor has given your VP-44 but the P0216 usually means not long. Are you having any symptoms other than the code?? i.e., dead pedal, excessive white smoke, low power/fuel mileage, rough idle... I'd clear the code(if you have a scan tool) and see if it comes back.
I had a P0216, VP-44 lasted 13 months fed by a FASS. It still died. Timeline would be as follows:
April 2004: Install FASS, after install checked codes and had the code.
August 2004: First instance of the dead pedal in hot Kansas weather, seemed to disappear for the winter unless I went on long drives. Heat seemed to be a factor.
March 2005: Dead pedal became more consistent. Nearly anytime the engine was at operating temperature the dead pedal would come with constant RPM. Dead pedal became more pronounced until... Other symptoms were truck sputtering upon letting out the clutch from a dead stop.
May 2005: After a 3 hour roadie, parked the truck at my house. Next time I went to start the truck I got billowing white smoke and an extremely rough idle... almost like a gasser with a large cam.
Old Feb 17, 2006 | 05:23 PM
cummnz4x4pwr's Avatar
Wink Time for the good ol p-pump conversion!!!!
If you start hunting down parts now then you can get the p-pump on for right at 2k pm me for details.
JMO
Jake
Old Feb 18, 2006 | 12:36 AM
Bart Timothy's Avatar
Chris
The 0216 code isn't good. Kind of blows a hole in the universally held theory that you need a fuel preesure guage and good fuel pressure to save your VP44.
Just wondering if your fuel pressure guage bounces?
Old Feb 18, 2006 | 03:53 AM
in2gpn's Avatar
It only bounces when the truck first starts up and the preheater kicks in and out other than that no real bounceing. The only thing I have noticed is the dead pedal 1/2 dozen times in the past month or so, no white smoke, no loss of power, and no rough idle. I might try and find a dealer that will warrenty it it I completly remove all signs of the Edge Comp mod. Don't really know what to do abouth the tapped wire other than play dumb if they asked me. If they don't warrenty it for me whats the BEST IP I can get for this turd and will it last for any lenght of time?????
Old Feb 18, 2006 | 06:39 AM
Geico266's Avatar
When you tap the wire on your injection pump you take matters into your own hands. I'd go with a Hot Rod Blue Chip rebuilt IP.
http://www.bluechipdiesel.com/VP44INFO.html
Terraizer
Dec 14, 2005 03:56 PM
Mopar1973man
14
May 18, 2005 07:54 AM
smokin_dodge5_9
Apr 1, 2005 08:04 AM
PDXDodge
Jan 14, 2005 11:23 AM
Steve10
Dec 19, 2004 10:27 AM
