Clutch recommendations please
Old Mar 30, 2009 | 07:25 AM
Little-bit's Avatar
I think I smoked the clutch in my truck this weekend. I power braked it Thursday evening and slipped the clutch a little in third gear. I let out of it and everything seemed to be fine. Well yesterday I was hauling an unloaded cattle trailer. I was running around 50mph and 1500rpm’s. I was in fifth gear and went to speed up. The RPM’s went up like I had broke the tires loose. “I wish it would do that”. I am hoping it is the clutch and not the transmission. Any thoughts there??
If it is indeed the clutch I need some recommendations please. It is the same truck that is on my sig. I haul a trailer a few times a year loaded around 10K pounds. I also have a bad habit with power braking every now and again. Can you guys recommend a good clutch and a supplier please…?
Old Mar 30, 2009 | 12:51 PM
Little-bit's Avatar
Back to top.
Old Mar 30, 2009 | 01:05 PM
Little-bit's Avatar
I called my local ORiellys auto parts store and priced their clutches. They have a standard clutch for $249 and a performance clutch for $389. Do you guys think the standard clutch will work for me?
Old Mar 30, 2009 | 01:18 PM
stevewes2004's Avatar
do yourself a favor and upgrade to a Southbend Con OFE. I found mine used in new condition for $375 and it holds the power that i have. you dont wanna be doing burnouts and launches with any single disk though.
Old Mar 30, 2009 | 03:54 PM
Gear Poet's Avatar
Second the suggestion of the SB Con OFE. You have an '02 like mine, so you should not have to replace the hydraulics - they'll probably hold.
Old Mar 30, 2009 | 07:04 PM
lvmknsmoke..'s Avatar
so u cant power brake a single?? dang it i might as wel go al the way an get a dual disc and do it right..
Old Mar 31, 2009 | 06:55 AM
well you can but they'll burn up a whole lot faster
Old Mar 31, 2009 | 09:25 AM
jmd025's Avatar
I like my Valair Kevlar/Ceramic single. Rated 500hp, decently smooth for moving trailers around, and pretty affordable.
I guess I never heard that I couldn't do a burnout on a single! LOL Oops too late.
Old Mar 31, 2009 | 12:14 PM
never said the word couldn't
Old Mar 31, 2009 | 05:38 PM
Midnite's Avatar
I decided to go with a Southbend Con FE. It's slightly more grabby than stock, and probably also the OFE (never drove a truck with one of those), but I wanted to do the clutch once and wasn't sure the OFE would hold up to where I might eventually end up power-wise.
I've been very happy with my Con FE, and I've been driving it for about 4.5 years now. And yes, I've power braked a little with it.
Mike
Old Mar 31, 2009 | 08:34 PM
ScottGregory's Avatar
I had a con OFe up untill I went stupid with "fixing" my motor. Many times I still whish I had it. Both the Fe and OFe are great clutches. Ofe was smooth and easy to back a trailer with.
Heck of alot easier in snow too. With my dual disk I just park it and wait till spring.
Old Apr 1, 2009 | 07:41 AM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
I am a big fan of Valair clutches. Their customer service (I always talk to Dan) is unbeatable. I had a 5 spd and upgraded to a six speed flywheel and clutch setup (con OFE). Last night i put an FE in my current truck and I love it. It is very smooth and I'm sure it will hold all the power I have. I am still breaking it in. I have also done plenty burnouts with the con OFE 13" in my old five speed truck. I have nothing but good words for Valair
Old Apr 1, 2009 | 02:03 PM
jmd025's Avatar
Pretty sure Con OFE and Con FE are designations for Southbend Clutches.
Valair just calls em by their friction material. Like organic-feramic, or feramic.
Jammie Dodger
Apr 23, 2010 12:18 AM
tmleadr03
Mar 18, 2008 04:02 PM
futchd
53
Jan 27, 2007 01:08 AM
tdm
Aug 22, 2006 10:00 PM
ashtiani
Aug 13, 2005 06:26 AM
