cluster out abs issue
Old Nov 11, 2024 | 09:11 PM
dobalina's Avatar
been on this for as issues for about 5 months
abs light has been intermittently n and off for last year and a half then cluster went out truck runs fine gauges on edge screen all read fine
unplugged abs module all gauges run except speed, put in new module and cluster no change.
I did have frontend ball joints replacement
any help greatly appreciate it
Old Nov 12, 2024 | 05:26 AM
Do it have 4 wheel ABS?
If so maybe the ABS lines where disturbed doing the ball joints.
Old Nov 12, 2024 | 08:35 AM
dobalina's Avatar
maybe' thanks! ill check into that.
Old Nov 12, 2024 | 01:49 PM
SIXSLUG's Avatar
It sounds like the sensors or the rings that pulse them....mine always comes on for a bit after a water crossing.....
You can do a dash op check on an 01,,,IIRC turn key off/on and press and hold odo button or something like that. Should light all warning lights, chime and walk/step gauges thru range..
Kurt
jda51
Aug 5, 2021 08:18 AM
shaft
20
Oct 24, 2018 07:23 AM
DodgeCowboy
0
Apr 14, 2016 09:41 PM
DodgeRam24V
0
Jan 7, 2012 06:02 PM
dieselfan
Jul 28, 2006 07:25 PM
