cleaning sensors
Old Apr 16, 2006 | 10:25 AM
scuzman00's Avatar
cleaning sensors
I have noticed a drop in fuel mileage lately and think it may be due to a dirty IAT sensor. I did a search and could not find anything on cleaning it. I know you can use Brakleen or carb cleaner. I would like to get info on location and any other specifics anyone may have. Any and all input is GREATLY appreciated.
Many thanks in advance!!!
Gary
Old Jan 8, 2007 | 05:59 PM
BlackSheep5's Avatar
still no answer? im wonding too what i can use to clean this sensor?
Old Jan 8, 2007 | 07:41 PM
DryCreek's Avatar
I cleaned mine a few months back. It is not too bad of a chore, but getting the sensor out was a challenge. It was pretty hard to reach until I managed to twist my arm in just the right direction. I think it was somewhere around a 1-1/4" socket that I used. Could be wrong though, I may have confused the size with the MAP (boost pressure) sensor.
Look on the back side (towards firewall) of the intake manifold and you will see the sensor, it is the smaller one, and I mean waayyy in the back.
Mine was covered in carbon (thanks to the exhaust brake) and I actually saw a difference in economy once I cleaned it up. My boost sensor will be next!
Dry Creek
Old Jan 8, 2007 | 08:16 PM
crobtex's Avatar
See if this helps.
Fuel System Components - 24-valve Cummins Turbo Diesel engine.
1. Fuel Transfer (Lift) Pump
2. Fuel Return Line (to Fuel Tank)
3. Fuel Supply Line (Low Pressure, to Engine)
4. Fuel Heater
5. Water-in-Fuel (WIF) Sensor
6. Fuel FilterlWater Separator
7. IA T Sensor
8. Map (Boost) Sensor
9. Fuel Drain Manifold
10. CKP Sensor
11. CMP Sensor
12. Overflow Valve
13. Drain Valve
14. Fuel Pressure Test Potts
15. ECM
16. ECT Sensor
17. Fuel Injection Pump
18. Throttle Lever Bell Crank and Apps
19, High-Pressure Fuel Lines
20. Fuel Injectors
21. Fuel Heater Temperature Sensor (Thermostat)
22. Oil Pressure Sensor
23. Fuel Injector Connector
24. Drain Tube
25. Intake Manifold Air Heater/Elements
Old Jan 8, 2007 | 09:44 PM
davemac's Avatar
scuzman00...
See if this helps
http://www.dodgeram.org/tech/dsl/sensors/IAT/clean.htm
afoulk
17
Apr 14, 2009 01:32 PM
BigBlue
15
Mar 28, 2005 01:20 AM
Bean
Aug 10, 2004 08:24 AM
dodgeboy59td
Oct 7, 2003 09:12 PM
tx_redneck81
0
Apr 10, 2003 09:24 PM
