Check your rear end.
Just checked the rear end grease for the first time and it was a quart low, Hope i didn't do any damage as the truck has 60000 miles on it. I read several post on low gear oil and was gonna check it but it just got overlooked for a while. There is no signs of leakage so i figured they didn't put it in there new, mine is a 2000 model so a lot of them could be low. Just wanted to remind everyone if you have not checked the grease level it would be a good idea to do it, and don't put it off like me.
Re:Check your rear end.
I checked, and my rear end is fine. Oh, and my truck's differential is in good shape too ;D Seriously, I check my diff every second oil change. I'm one of those better safe than sorry kind of guys.
DeWain
DeWain
The axle seals are fine, i think they just didn't fill it up. I know it should be changed more often but it would depend on how much pulling you do with the truck. I may change it this weekend.
[quote author=DeaconWayne link=board=4;threadid=9907;start=0#95039 date=1043257970]<br>Doctor checked it about 3 weeks ago
<br><br>I'll get the results tomorrow.<br>[/quote]Had that done about a year ago, NOT funny.
Just FYI, DC states that on all Dana rear axles, they're full when the fluid level is 3/4" BELOW the fill plug. For the Dana 60F front axle it's 1/2" below the fill plug. So in other words, don't fill 'em up till they're running out. Just contrary to what I've always done in the past.<br><br>I found this out when refilling my Dana 80, as the 5.05 quarts didn't flow out of the filler. Did some checking and that's what I found in the owner's manual.
[quote author=Ruralmedic link=board=4;threadid=9907;start=0#95058 date=1043260196]<br>Just FYI, DC states that on all Dana rear axles, they're full when the fluid level is 3/4" BELOW the fill plug. For the Dana 60F front axle it's 1/2" below the fill plug. So in other words, don't fill 'em up till they're running out. Just contrary to what I've always done in the past.<br><br>I found this out when refilling my Dana 80, as the 5.05 quarts didn't flow out of the filler. Did some checking and that's what I found in the owner's manual. <br>[/quote]<br><br>Good info..Thanks
Red:<br><br>Bad news, if your truck came with the anti-slip rear, and you really haven't changed your diff fluid in 60,000 miles, you most likely now have an open differential. My money says your clutches are shot.<br><br>Hope I am wrong.
Changed mine at 61000. Royal Purple Max Gear 75w140. <br>3.55 Dana 80---- 3.75 quarts to the fill plug :
there seems to be a lot of differences on how much fluid it takes to fill.<br>wk
