Check engine light poped on my 99
Old Jan 5, 2009 | 10:01 PM
jiMMyCTD's Avatar
Ok, now before the search wagon screams at me I am asking because the site is tell me to - PS - im searching right now also, Slow internet at the house.....
"Hello jiMMyCTD it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums? "
So here I am seeking suggestions before I head to the parts store sometime this week to have them run the reader(i tried the key cycle, no luck)
Here is what happened and what i have tried so far.
I have had this truck for almost 4 years now. It is used for towing and otherwise gets driven at least bi weekly. I have ZERO issues with it. it has 110k miles on her. I was driving into town and noticed my edge comp was not on. So i hit the power button and nothing turned on, ok no biggie ive read on here where sometimes they get flakey. So at the next light i reach behind and unplug the module. Instant check engine light came on. Ok so i think it saw an open circuit. I pluged it back in and the box came on, traffic starts going so i test the box on every leval. Works normally again BUT the check engine light is on still, ARG... So after my stop in town i come out to the truck she starts up normally, edge is on, check engine light is STILL on. Truck runs fine on all levels of the edge and when i turn the edge off. FP is fine and normal. all over gauges reading normal and acting normal and truck works perfect. all i did was unplug the edge with motor running and now the check engine light is on.
Any tips/tricks/ or tribal knowledge would be great. All i have done since i got home was remove the battery cables and clean them off for good measure(yes ill have to reset my presets on the radio) LOL.
Old Jan 5, 2009 | 11:15 PM
rebal's Avatar
sometimes it take 3 cycles of the key (3 starts) and the light gos out if theres a issue the light stays on. try starting it ...run it...start it again ...etc. see if it gos out
Old Jan 6, 2009 | 12:34 AM
Zeus1987's Avatar
Assuming the comp also taps into the MAP sensor. I had a similar problem when i unplugged my juice harness from the box. did a quick scan of codes and i found P0237 something about the MAP sensor. cleared the code and hooked the juice back up and no more CEL.
Old Jan 6, 2009 | 05:40 AM
98whitelightnin's Avatar
I unplugged the quad box from the 03 when it was running one time and it started running like crap. Check engine light came on, I plugged it back in real quick and it still ran like crap. So I turned it off and cranked it, it ran fine but the light was still on. The next time I started it all was good, ran fine and no CEL.
Old Jan 6, 2009 | 12:16 PM
jiMMyCTD's Avatar
Hmm, wierd. Well im gonna drive it into town tomorrow probably and see what happens.
Old Jan 7, 2009 | 03:31 PM
jiMMyCTD's Avatar
well took her into town. filled her up with fuel. CEL still on. truck driving normally. goto local to pull codes. returned only 1 - P0237 Turbocharger Boost Pressure Sensor Low. he unplugd the reader, i strted it up and no more light. giddy up!!!!!!
patpat paul
Mar 16, 2008 12:11 PM
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
