Changing Rear Diff Fluid
Old Jul 1, 2005 | 09:51 AM
infidel's Avatar
When I got mine it was full to hole from the dealer...
Most all mechanics fill to the bottom of the hole, it's been this way for years. It's always seemed silly to me that the earlier Danas level were supposed to be below the hole. Perhaps this is why our trucks are so prone to axle leaks compared to others and also the reason the hole was lowered later.
I've found it best to follow the specs that the manufacturers state for oil levels and types, it's in their best interest that the product lasts as long as possible.
Read your manual.
Old Jul 2, 2005 | 10:48 AM
Supermod56's Avatar
Hey guys, on my 01 did I screw up and put too much in the front when I filled it to the bottom of the hole?? The reason I ask is I'm overseas and can't check my manual!! Anybody out there that can check their 01 manual and let me know??
Thanks
Tom
Old Jul 2, 2005 | 12:11 PM
dodgediesel4x4's Avatar
If you have access to a jack, I would jack up each side of the axle, one at a time, to try and get all the fluid out. The more you can get out the better.
Old Jul 2, 2005 | 11:38 PM
Fueling around's Avatar
Does the manual recommend anything when changing from a 70W-90 to a 75W-140 or vica-versa?
Some OEMs requires a fill, flush, & re-fill because the lubes are not compatable.
BTW, mine leaked from the pinion seal after over filling. Once down to the "find it with the pinky" level, the pinion seal is fine.
Old Jul 3, 2005 | 12:55 AM
infidel's Avatar
I've never read anything about flushing it but would at least jack each side separately to drain oil to the middle then wipe up the excess oil that doesn't drain out with a rag.
Old Jul 3, 2005 | 11:59 AM
Dr. Evil's Avatar
Originally posted by castro
SOME HAVE GASKETS SOME DONT MINE DOES GIVE THE DEALER YOUR VIN AND HE WILL TELL YOU THE COST IS $33
I believe that only third gens with the AAM diffs have the gaskets
banana
Dec 1, 2009 11:44 PM
BossHogg
51
Sep 2, 2007 12:41 PM
nitis
Apr 29, 2007 07:32 AM
Lrdchaos
Oct 1, 2004 10:20 AM
BradN
Mar 13, 2003 07:32 AM
