changing rear diff fluid
Old Apr 29, 2007 | 01:24 AM
nitis's Avatar
ok going to change at least my rear diff fluid tomarrow what weight should be used I do not tow but thought I read where dodge had a tsb recomending people upgrade to 75 140 from 75 90 which should I use dod I use this in the front too? What does my tranny take? and no new gasket needed correct?
Old Apr 29, 2007 | 01:42 AM
Luvnacumns's Avatar
75-140 limited slip is what I put in the rear diff. Can't remember the tranny but it was cummins aproved got it at napa..
Shane
Old Apr 29, 2007 | 06:26 AM
bulabula's Avatar
I've used both Amsoil MTF and Redline MTL in the tranny. No gasket required for the tranny. Nothing special required but you will need about 4.5 quarts for the transmission, and a 17mm hex to remove the fill plug.
Old Apr 29, 2007 | 07:32 AM
timcasbolt's Avatar
Shane
Doesn't need to be limited slip. You've got a cummins transmission?
banana
Dec 1, 2009 11:44 PM
BossHogg
51
Sep 2, 2007 12:41 PM
Pike
20
Jul 3, 2005 11:59 AM
Lrdchaos
Oct 1, 2004 10:20 AM
BradN
Mar 13, 2003 07:32 AM
