carrier bearing help
Old Jun 5, 2011 | 06:51 PM
DIESELWRKS's Avatar
okay the search bar keeps timing me out without giving me info.
so the carrier bearing what is the easiest way to remove it.. do I need a press or can I do it with other pipe pieces. and the only one around me reasonable price is through napa. skf brand..
Old Jun 8, 2011 | 07:48 AM
RowJ's Avatar
Yes, need a press to get bearing off shaft. You can drive new bearing on with hammer.
There are two different type carrier bearings (Dodge calls it a 'propeller shaft center bearing'). They are not interchangable.
My NAPA replacement has been good for over 100,000 miles.
RJ
Old Jun 8, 2011 | 04:43 PM
DIESELWRKS's Avatar
great thanks napa only shows one bearing skf for those years. good I get a discount as a veteran federal employee. sounds great to hear its lasted that long..
Old Jun 9, 2011 | 07:06 AM
RowJ's Avatar
I do not remember two choices either, but Field Service Manual says there are??
I don't really remember having to press the bearing off, either. Just regergitating from the book.
RJ
Old Jun 9, 2011 | 01:40 PM
DIESELWRKS's Avatar
thanks again for the info. let ya know what I break removing it.
Old Jun 10, 2011 | 06:22 AM
vp dually's Avatar
How many miles do you get out of them from the factory? What are the symptoms of it needing a replacement.
Old Jun 10, 2011 | 07:08 AM
RowJ's Avatar
There was a time back in 04-05 when a lot of posts talked about needing to change out carrier bearings. It was a time when many 2nd Gens were in the 100,000-150,000 range.
I was replacing 2 u-joints at 110,000 and since I had my drive shaft out, I did the carrier also. Mine looked fairly warn but not dead.
RJ
Old Jun 10, 2011 | 05:32 PM
DIESELWRKS's Avatar
I have 185k and with 60k with my lift and putting a new engine in the truck last year I'm slowly replacing parts here and there.. my u-joints and wheel bearings and ball joints did those over winter. now its carrier, and soon the leaking vac pump and power steering seal..
Old Jun 22, 2011 | 04:01 PM
totalloser's Avatar
At about 270k of relatively heavy use, my carrier bearing started giving me trouble. Kept popping out of the bushing. Found that the plastic on the splines of the second piece was peeling off and binding up. BIG pain. Tried many things (even a pillow block) before just having a 4" single piece made. Problem solved.
Old Jun 22, 2011 | 08:02 PM
gorms's Avatar
A press is not needed. Mine was almost 200k miles old in the salt belt and it came off with 2 chisels pounded in to wedge it off, then a punch to get it all the way off.
There are two types, an expensive and inexpensive. One hangs down a bit (overall bearing assembly) and bolts from the back of the bracket, the other has 2 ears off the side that bolt through the bracket and is a bit shorter. THe shorter one is about half the price and lasts just as long, so 2 pieces of 1" sq tubing side by side make up the difference nicely. I just welded them to the bottom of the hanger bracket and bolted through the gap in between them, and it worked great.
Just make sure you get the ID on the bearing right, FWIW mine is 1.550".
Old Jun 22, 2011 | 08:29 PM
rocket82's Avatar
I just did mine a little while ago. 460 000kms fubar. change out was easy. take your time and it'll come apart.
ajb1974
Mar 18, 2015 05:49 PM
Megaramasaur
Oct 18, 2008 10:32 PM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
Stroke This 24V
Jul 3, 2003 02:40 AM
rich
0
Oct 4, 2002 06:18 PM
