camber bushing???
Old Apr 22, 2006 | 01:06 PM
ncdodgeman20's Avatar
camber bushing???
whats going on people? i need some advice the other day i walked around the front of my truck and noticed that the driver side tire is wearing on the inside pretty bad comepared to the outside of the tire the inside of the tire is about balled and the outside of the tire looks new but so i took it to an alighnment shop and had them look at it and right off they said i need a camber bushing replaceed and they said its because that the top of the tire is laening towards the motor and he said iam looking at around 250$$ does this sound right??? or is this someing you can do yourself??
Old Apr 22, 2006 | 01:18 PM
nitrousn's Avatar
If the ball joints are good then some thing has changed. Possible bent axle housing. I would inspect all the components and then get it on a alignment rack and get a copy of the readings and go from there.
Old Apr 22, 2006 | 01:20 PM
nitrousn's Avatar
OOPS i see you are a two wheeler. I thought the camber was adjustable on the 2wd models?
Old Apr 22, 2006 | 04:53 PM
johnh's Avatar
250
shop around, i`m sure you can find parts installed cheaper
scjfly
Apr 2, 2012 11:40 AM
xp8103
Nov 8, 2004 10:59 AM
Puke
Jul 23, 2003 01:07 PM
dma251
Jun 19, 2003 04:17 AM
