Cam Sensor
Cam Sensor
I'm getting a bunch of codes......1690, 0215, 1689, 0219, 0341. I did have one very brief dead pedal for about 2 seconds about 4 days ago but nothing since. It's running fine and that includes excelerating on the freeway above 60 MPH. I have an intank lift pump and my pressures have remained consistant thru to course of issues at 9 psi idle/6-7 psi while cruising around. My tach has been acting up and hanging out down at zero briefly.
Of course I'm fearing the worst suspecting I may need a new IP. Can a bad cam sensor cause all these codes and the dead pedal????
I'm afraid to drive it because I don't want to add a tow cost to my troubles. I'm pretty new to the diesel scene and have only had the truck for a short time. Can the IP be slowly failing or do they go out all at once?
Thanks in advance.
Thanks in advance.
bad cam sensor can cause the dead pedal,
my tach was playing fuzzy too
i had this trouble about 2months ago,code 216 even showed,i was feareing the worst,i changed that **** hard to reach sensor and no code anymore...
btw the cam sensor bolt is an allen one and the cam doesnt screw in even if its seem to be built like that,only push in
etn550
Apr 1, 2010 12:12 PM
Gabe32
16
Feb 22, 2007 06:37 PM
