Cam position sensor
Old Jan 20, 2008 | 02:01 PM
robert78.5's Avatar
Cam position sensor
I hooked up a code reader and everything checks out except the cam position sensor. it reads 0 all the time running or not. The boost pressure also won,t go lower than 15 lbs. even with the engine not running.
Old Jan 20, 2008 | 07:19 PM
sweeney186's Avatar
Got a code 0341?or just reading 0?15 psi is normal atmospheric pressure(normal air pressure)
Old Jan 20, 2008 | 07:33 PM
robert78.5's Avatar
Just reads 0 for the cam position. No code.
dozer12216's Avatar
The gauge should show PSIA and pressure near 14.7 without boost.
Absolute pressure on Chrysler scanner, others may not be the same.
Old Jan 20, 2008 | 07:36 PM
torquefan's Avatar
I believe they discontinued the cam sensor on the 01 engine, so that line on the scanner will read zero.
Old Jan 21, 2008 | 12:15 AM
Russ Roth's Avatar
My '01 has the cam sensor and no crank sensor.
Old Jan 21, 2008 | 09:41 AM
robert78.5's Avatar
My manual says' that the cam sensor is only used for diagnosis purpose. It states it is not used to control injection pump, is this correct?
Old Jan 21, 2008 | 04:08 PM
sweeney186's Avatar
The cam sensor does have some other uses-but if you have no codes-its very possible the prob is just your scanner
BarryG
Aug 26, 2008 03:59 PM
GreatTruck2001
Mar 31, 2008 04:44 PM
DanTaylor
Apr 23, 2007 08:27 PM
ILIANBG
Dec 11, 2006 04:49 PM
ram4fun
Feb 28, 2003 06:42 PM
