Cab swap "st" to a "slt"
Old Oct 2, 2015 | 09:42 AM
GCCUDA's Avatar
I am swapping a 1998.5 SLT quad cab 24v auto,cab over to my 1999 "St" 24v 5 speed
I am using all the wiring from under the hood off my 1999
Questions and concerns are the SLT cab was auto .I am using the dash and harness FROM THE 1998 SLT . WILL THAT MATTER ?
ANY THOUGHTS !! ANY ADVICE!!!ANY PROBLEMS THAT ARE COMING MY WAY?
Old Oct 2, 2015 | 02:17 PM
Mcmopar's Avatar
The dash cluster will have a shift indicator light
Old Oct 2, 2015 | 08:08 PM
GCCUDA's Avatar
Yes that I was thinking about. I have the column from the stick truck I am going to switch over and the dash . this will leave the indicators unused do you think that it will be an issue?
Old Oct 3, 2015 | 08:45 AM
Mcmopar's Avatar
I don't know if the wiring from the auto truck will have the "clutch safety switch" provision either.
Old Oct 3, 2015 | 09:39 AM
GCCUDA's Avatar
YES that is a concern ! HMMM! I will have to have a look . hopefully some one has an answer to that
Old Oct 3, 2015 | 11:57 AM
SIXSLUG's Avatar
There are some past threads on this type of change over, usually regarding a wrecked truck salvage that covered every detail. Since yours is inside a certain model range (quad cab to quad cab) it should be relatively easy. The difference between ST and SLT is just trim levels and power accessories. Hopefully your new cab has all the slt wiring for the doors and overhead display, heated and power mirrors etc.
I'd search "cab swap" and see what you find....
Old Oct 3, 2015 | 01:24 PM
GCCUDA's Avatar
YA the cab has the slt wiring in it , and the doors also . I have done a search but was able to find any thing that is significant to get the right info. ill try again
Old Oct 3, 2015 | 10:09 PM
torquefan's Avatar
I believe they all had the wiring for that, and the autos simply had a jumper plugged into the connector.
Old Oct 4, 2015 | 08:53 AM
GCCUDA's Avatar
Yes I have heard that but I have been unsuccessful in finding anything so far
Anyone know where I might find this info?
I am putting an auto cab and wiring on my stick chassis
Old Oct 4, 2015 | 12:17 PM
torquefan's Avatar
If you have the donor cab in your possession, it should be fairly easy to see.
Have a look at your manual truck and see where the clutch switch plugs into the harness under the dash. The auto truck should be just the same, except there'll be a jumper plugged into that connector instead of a clutch switch.
Old Oct 5, 2015 | 09:06 AM
GCCUDA's Avatar
OK I will look for that . this is great info Thank you guys
Anything else that might be of concern?
Old Oct 5, 2015 | 05:11 PM
GCCUDA's Avatar
Torquefan the indicator from the auto can ? do you know what might need to done with that .Also I am thinking to change over the column from the stick cab . but I like the idea of the tilt column that the auto cab has. any advise?
Old Oct 6, 2015 | 10:06 PM
torquefan's Avatar
I can't remember the auto trans indicator on the 98.5 trucks, is it digital, or is it the same as the old ones where an orange square moves from segment to segment as you move the lever? If it's like the old mechanical ones, it's easy to unscrew from the cluster and replace with the blank panel from the donor truck. It simply has a little cable that clips on to the shift collar on the column.
As for the column, it should be an easy swap over to a manual trans column. Or, you can just remove the lever from your existing column by pushing out the retainer pin at the base of the lever, and run it like that. I don't think these columns will come apart to exchange parts between the two, but someone else may have a better idea.
Old Oct 7, 2015 | 11:22 AM
GCCUDA's Avatar
I don't know for sure if it was a digital or the old one. but there was a cable that ran to the dash cluster that wrapped to the underside or the column and it had an adjuster to adjust the tension .
Would that be the one you were referring to?
The dash had be stripped of a few pieces before I got it
I had another though . can the ST dash be put in and the wiring for the power options be plugged into the St fuse panel ? there are fuse openings in the St .but of course they are empty because its an ST.
Old Oct 10, 2015 | 08:38 AM
GCCUDA's Avatar
Can the ST dash be put in and the wiring for the slt power options be plugged into the St fuse panel ? there are fuse openings in the St .but of course they are empty because its an ST.
Anyone know?
