Bypass valve bolt
Old Jun 5, 2007 | 07:58 PM
leew's Avatar
Bypass valve bolt
Just had the vp44 replaced. For the last day or so the truck is hard to start...I have checked for leaks. NONE But I removed the bypass bolt and it has a very small weep hole made into it. I assume so some fuel always bypasses it. I'm wondering if this is causing it to lose prime. I have 15 psi at idle and 11-12 at wot ... running holley blue on frame rail with large igniton resistor to quiet it down a little...Works great......Any thoughts on hard starts?
Lee
Carlton,TX
98.5 24v (With a PUCK)
Old Jun 6, 2007 | 08:20 AM
Tocapet's Avatar
What kind of pressure you getting with the Holley Blue?
Too much will get you hard starts. Is it hard to start right after you run it or is it after it sits awhile? Are you sure your Holley is not sucking air somewhere?
Old Jun 6, 2007 | 04:07 PM
leew's Avatar
Without the resistor ... its a little under 20. With it ... right at 15.
The truck is hard to start after I have driven it and it is warm and sits for 10-15 minutes.
FordTrax
Apr 18, 2014 08:47 PM
wrglrroper
Aug 17, 2006 12:46 PM
mdryan
Aug 23, 2005 09:33 AM
Guy
Mar 12, 2003 12:00 AM
