Buying a Dodge truck (today, .....help!)
Old Jul 4, 2006 | 01:23 PM
na4now's Avatar
Ive been looking at a couple trucks, and Im really thinking about this one. Its an 01, and has 144k miles for $15,500..
Thing is, ... I was talking to this guy, ..He said to stay away from 2000's and 01's, because some of them had a bad batch of engine blocks. He said they have a stamp(casting mark) on the front drivers side, of the block, but he didnt know what number to look out for. Supposed to be a 53, or a 55 .?.?.?
Does anyone know anything about this?
Heres the truck:
Thanks.
Old Jul 4, 2006 | 01:34 PM
turbo dreams's Avatar
it's called a 53 block. they have problems with some cracking. the number 53 will be stamped on the block on the drivers side. mine is a 53 and it is a 99 model. i have over 227,000 miles and no problems. i don't think anyone knows the truth about if a 53 will crack or not. but i have always heard if they do than they will before 100,000 miles. i am not loosing any sleep over mine. good luck and i would buy that truck for 15,500 anyday.
Old Jul 4, 2006 | 01:52 PM
na4now's Avatar
Thanks alot.
Is there any way to tell what gears the truck has, just by looking at it?
Old Jul 4, 2006 | 02:07 PM
CTD01's Avatar
Gears
If you open the glovebox there is a sticker that tells you what the gears are and if its an anti spin diff (posi). Truck looks real nice good luck,
Paul
Old Jul 4, 2006 | 02:09 PM
dssimecek's Avatar
Nice looking truck. Should be a plate or sticker in the glove compartment door that has the gear info. Also delaler can give you a build print out of the vin number. Some will do it for you no charge.
Good luck on the truck.
Old Jul 4, 2006 | 02:10 PM
SIXSLUG's Avatar
Buying a dodge truck(today,....help!)
Nice looking rig! For gear info look in the glove box . There's a sticker that lists the axles the truck was built with. Also, there should be a metal tab on the diff's cover bolts, look closely, they get hidden by road grime. If not, you can jack the rear and rotate the tire one full turn while counting the driveshaft revs(oldschool way). Both front and rear better match if the same size tires are on it! Good Luck, Kurt
Old Jul 4, 2006 | 02:17 PM
OUTDOORSMAN's Avatar
sweet looking truck....
Old Jul 4, 2006 | 02:37 PM
TNutcher's Avatar
That truck is sweet!!! lol looks good! Yeah with the one ton dually usually they would be 4:10's I'd guess... anyway let us know how it all goes!!
TNutcher
Old Jul 4, 2006 | 03:00 PM
Tate's Avatar
There may also be a sticker on the the hood with gear info. Are those 215/85 tires on it, or are they a worn out set of 235s? They look small.
Old Jul 4, 2006 | 09:41 PM
GlennRMK's Avatar
Is it an 01.5 with the rear discs or an early 01 with rear drums?
I have never seen an 01.5 with the 53 but it is possible. Almost all the 98-00 trucks I looked at had a 53 block.
Its on the drivers side, right above the oil pan, and only a few inches from the front of the motor.
Old Jul 4, 2006 | 10:04 PM
1-2-3's Avatar
Just a plain ole guy
You can find the 53 by laying on your back, and look up at the bottom of the oil pan on the drivers side, right inder the injector pump. The #53 will be cast into the block whaere it meets the pan. i have a 53 block, 113K miles and no cracks.
That is a nice looking truck. I'd buy that in a heartbeat. If you do get it, you need to imeadiatly install a fuel pressure gauge so you can see it at all times while driving. The biggest issue they have is the lift pump going out, but the injector pump is strong enough to pull fuel through it from the tank, but the extra work will kill it, and it's about $1500 to replace it.
Search this site for 53 and lift pump and you'll get tons of info on it.
Old Jul 4, 2006 | 10:53 PM
na4now's Avatar
Well, Ill be finding out if its a 53 tomorrow. The truck was on ebay, and I just bought it. The guy wasnt around the truck to check for me (before the end of the auction).Im flying to Fort Worth Texas, tomorrow.
You guy check it out and tell me what you think.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=018
Old Jul 4, 2006 | 11:07 PM
MOAGGIE's Avatar
Nice looking truck, I wish I could have found mine in that color. Good price too. Enjoy.
Old Jul 4, 2006 | 11:15 PM
dodge2001's Avatar
Smile
first off, good looking truck. second with it being an auto the diff should be 4:10, and look at the eight number from the right on the vin. if it's a six, like yours is, it's a non HO, if it's a 7 than it's and HO. oh yeah and it's the early 01 so you got the drums
Old Jul 4, 2006 | 11:55 PM
na4now's Avatar
So it is an early 01. Maybe Ill get lucky, and not get a 53 block.
