broken transfercase mount!?
Old Apr 14, 2011 | 08:12 PM
rocket82's Avatar
Hi all,
I was under my truck today and i have a few questions, my hangar bearing seems really soft and flexible, is this right? It doesnt seem to have any looseness, just softish rubber...
Next thing is when i grabbed the front of the rear driveshaft to check for play i noticed i was lifting the transfer case up. I reckon there should be no play there but maybe a little wiggle room but not the ability to lift it up an inch!
Please lemme know what you think... any thoughts on cost/ difficulty to change. Thanks!!!
2002 ext cab LB $x$ (4x4) auto, 35's, MBRP exhaust.
Old Apr 14, 2011 | 09:52 PM
totalloser's Avatar
Sounds normal to me. There is a bushing on the trans case mount and you can move it. Same for the carrier bearing- these bushings prevent drivetrain noise from transferring to the frame, and into the cab.
Old Apr 15, 2011 | 11:44 AM
evil-diesel's Avatar
Sounds like the bolts holding the transfer case to the transmission have loosened off, my truck was like that when I first bought it, a bad vibration from the rear drive shaft caused this.
NoSparkplugs
Apr 30, 2008 11:27 PM
Rpainter
21
Mar 8, 2008 02:36 PM
Bulldozer
0
Feb 3, 2008 03:17 PM
97ramctd
Nov 13, 2006 08:04 PM
jiMMyCTD
Jun 27, 2004 07:54 PM
