Brake job the good old drums!!?
Old Oct 19, 2010 | 09:49 AM
clowndodge01's Avatar
Well I had to replace the prebent factory line that goes from the front all the way to the rear, yea it decided to rot while I was drivin and I lost ma brakes. But now to the question I'm going to overhaul the rear drums as well, when I go to autozone they are tellin me a 2001 dodge does not according to there comp have rear drums soooo me and the tech in the store he's a smart guy as well as me I say well let's just order the stuff for a 2000 with drums? Am I right in doing this and are they the same parts I'm hoping as a 2001 with drums? Thanks to all
Old Oct 19, 2010 | 10:43 AM
KATOOM's Avatar
http://dodgeram.org/tech/specs/brakespecs.htm
Old Oct 19, 2010 | 11:45 AM
So I'm guessing I was good in ordering parts for a 2000 thanks for the post
Old Oct 19, 2010 | 11:18 PM
johnh's Avatar
tell him to get the parts for an '01
Old Oct 20, 2010 | 06:21 AM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
...Seems like the obvious answer. I swear these parts stores must be the number one cause for stress-related heart attacks. They do nothing but make my blood pressure rise. I'm sure the 00 kit will work.
Old Oct 20, 2010 | 09:20 AM
Oh I told him and I know the guy and he knows my truck is an 01 but the computer refuses to recognize the truck has rear drums, so we had to do it as a 2000 yr model
Old Oct 20, 2010 | 09:21 AM
Wow your spot on?
Old Oct 20, 2010 | 04:33 PM
mini14's Avatar
do the wheel cylinders while your at it cheap and easy.
Old Oct 21, 2010 | 10:08 AM
dizzel's Avatar
I could easily be wrong but did the 01 have a factory rear drum upgrade?
IIRC there was a change of some sort
Old Oct 21, 2010 | 11:25 AM
KATOOM's Avatar
If I remember right, in 2000 the drum size changed from 13x2.5 for the 2500's and 13x3.5 for the 3500's to 12.125x3.5 for the 2500's and the 3500's.
Old Oct 21, 2010 | 11:32 AM
nkennedy's Avatar
2001.5, or late 01 models, have disk brakes.
Old Oct 22, 2010 | 07:17 AM
this turning into a pain for me now once i got the pass side off the shoes look brand new the driver side was worn all the way to the rivets? hmmm
Old Oct 22, 2010 | 12:52 PM
KATOOM's Avatar
How did the auto adjusters look? I bet one is frozen and the other still worked.
Old Oct 22, 2010 | 01:07 PM
Yea they both look nasty but I'm thinkin that pass side was froze up, now a new one I'm gettin nothing but air on the driver rear when I bleed the line well not all air there is fluid but not solid, it's more air than fluid. All the other lines are solid fluid when I bleed them and I'm using one of the pneumatic deals from harbor freight to bleed. I've went through 3 qts of fluid tryin to bleed the line and still got air??
Old Oct 22, 2010 | 03:40 PM
KATOOM's Avatar
Well that just doesn't make sense does it..... You'd have to have a leak somewhere to be sucking all that air and a lot of fluid escaping, especially since the other side is fine. Which also means that the problem is at least not that far away.
