Brake hop
Old Apr 23, 2003 | 11:45 AM
bkay's Avatar
Brake hop
I have noticed as of late that the rear of the truck seems to hop when the brakes are applied. This is at about 30 mph coming to a stop. My first thought was my rotors are warpped, but it hop or bounce is coming from the rear of the truck. Almost like the road has bumps in it. ???
Old Apr 23, 2003 | 12:17 PM
DF5152's Avatar
Re:Brake hop
have u pulled of the rear wheels and checked the brakes. Could be improper adjustment. Sometimes if you have leak, wheel cylinder or gear oil it will cause aproblem like that.
Old Apr 23, 2003 | 02:06 PM
redruM Hauler's Avatar
Re:Brake hop
interesting<br><br>mine does this too ???
Old Apr 23, 2003 | 02:10 PM
bkay's Avatar
Re:Brake hop
I'm wondering if it has something to do with the anti-lock brake system. Talked to two other guys at lunch one drives a 1500 the other a 2500 diesel they both say their trucks do this also. Both are Dodges.
Old Apr 23, 2003 | 04:18 PM
DieselDaze's Avatar
Re:Brake hop
Could it be that the drums need to be turned?<br><br>If theyre disk in the back, then maybe the back rotors need to be turned?<br><br>Im just takin' a stab... I dont know.<br><br>Rich.
Old Apr 23, 2003 | 09:09 PM
Stamey's Avatar
Re:Brake hop
Supposedly brake fluid or gear lube on the shoes will cause this, but I have never personally seen it happen.<br><br>Chris
Old Apr 24, 2003 | 05:04 AM
Tiny's Avatar
Re:Brake hop
bkay, pull your drums, I would venture to guess you have have a bad axle seal. Both mine went bad on the Dana 70, had to pull the axles to change the seals. Got them from a dealer, ones from Napa or Autozone do not hold up to the task. If they are leaking, replace BOTH sides, new shoes, etc. Have drums turned. Hop will disappear.
cheap
Sep 21, 2010 06:44 PM
Cougar_333
Feb 12, 2004 02:39 AM
xj2extreme
Feb 20, 2003 10:38 PM
dodgeram
Nov 30, 2002 08:17 PM
