blowby solution?
Old Oct 8, 2003 | 04:59 AM
SilverDiesel's Avatar
blowby solution?
this was a brain fart, but why don't we put a pump on our blowby tube and plumb it to our exhaust or something? and i thought i read somewhere that having negative crankcase pressure actually helps make more power. this idea is probobly retarded so flame away
Old Oct 8, 2003 | 09:47 AM
thumper 549's Avatar
Re:blowby solution?
they went to some sort of a pcv valve i hear in 2002 ,mabe it could be up graded??
Old Oct 8, 2003 | 12:33 PM
BigBlue's Avatar
Re:blowby solution?
My 01 still has the little catch can on the front of the engine. I need to empty now that I think of it. Thanks for posting and reminding me about it.
Old Oct 8, 2003 | 12:35 PM
dodgeman01's Avatar
Re:blowby solution?
do the 0lder 12v's have this because I never touched mine :
DM01
Old Oct 8, 2003 | 10:17 PM
KATOOM's Avatar
Re:blowby solution?
Dont knock the fact that these trucks have a open loop crank case vent. This is a good thing. Any devise (pcv valve, ect.) that puts expelled fumes back into the motor is hurting power. Thats only emission stuff. Just run a 3/4 in hose from the existing down under the truck and the bottle problem is gone. Just be sure not to let the hose droop so as to allow a fluid trap or you'll blow out seals.
Old Oct 9, 2003 | 02:22 PM
Trashdawg5050's Avatar
Re:blowby solution?
Has anyone tried using crank case vaccum pump? Like what they use on high performance gassers to creat a better piston ring seal.
Old Oct 10, 2003 | 12:55 AM
Re:blowby solution?
yeah thats what i was talking about...negative pressure in the crankcase and getting rid of the oil at the same time.
csramsey640
Aug 29, 2005 01:24 AM
1ST GEN.
Jul 6, 2005 12:03 AM
I SPEED
Dec 20, 2004 03:17 AM
KATOOM
Apr 29, 2004 12:25 AM
Evildiesel
Oct 29, 2002 05:22 PM
