Blowby and oil usage
#62
I want to see the outcome of this one. I've never heard anything about valve seals causing this but I guess it could. Been rebuilding and machining engines for over thirty years and haven't heard of this. Some of the heads that I have rebuilt from turbocharged diesels don't even have seals. I have seen valve guides and valves so worn that compression would go past them. Doesn't seem likely that there is a problem with the bottom end based on the compression test. Good luck, waiting to hear what you find.
#63
The compressor side of the turbo (intake) has a vacuum, it has to pull air through the air cleaner. Like I said, leak down is a waste of time, for the cylinders. It does have uses though.
The only way any sort of vacuum can be obtained it through resistance like a plugged air filter. If you dont believe me put a vacuum guage on the filter box. The only time any negative pressure will be obtained is from a severely plugged air filter. As long as the filter is good there will never be any sort of vacuum.
#64
It does?? Please explain how.
keith
#65
#67
well i just put 15 pounds presure into the intake, and i have 4 intake valves that are leaking enough air past to see and hear it. i can move the valve stems back and forth, and watch the air leak move around. at 30psi, there is alot of air moving past those 4 valves. so it looks like the head needs to come off at the very least. i will check the bottom end(rings, cyl walls, pistons) once i have the head off and see what the rest of it looks like.
anyone have machine shop recomendations?? i guess ill have it o-ringed and do studs while im at it, since i do plan on bigger sticks and a turbo in the future(later than sooner now).
should i be concerned about doing alot of work to the #53 block. its held up this far, but thats with rv275s and a stock hx35.
another option would be to try and find a complete used engine, non-#53 of course.
whats everyones thoughts???
#69
I second that and it will not be that much time or energy wasted in the event it does not fix the issue. That is unless this blow by is a good excuse to fire ring the head!!!!!
#72
Thank You for sharing ! I am glade you found your problem . I would like a answer on the short trip question , How bad is it to not get the temp up on the motor . I take my dog to the park about 6- miles round trip . I live in califorina , was thinking of blocking off the grill to get some temp in the motor.
Thank You !
Thank You !
#74
