Blow By and Crankcase Pressure
Old Jun 16, 2010 | 06:25 AM
Redliner's Avatar
Recently noticed that im having ALOT of blow by on my truck. Head gasket has beed seeping some oil outwards for about a year. Also if you get on it anything over 20psi, the oil dipstick tube pops out. Any Ideas???
Old Jun 16, 2010 | 12:19 PM
sheriffav8r's Avatar
You have a blown head gasket.... Take off the oil filler cap and see how much pressure is coming out when you idle the engine.... Also, check your coolant for oil/sludge. It's a lot of fun....
Old Jun 17, 2010 | 06:35 AM
Redliner's Avatar
No oil in antifreeze. Its been leaking some oil from around the head gasket at the front for about 15k. Stock gasket and stock bolts 210K on them. I figured this much.
Old Jun 20, 2010 | 09:45 AM
dozer12216's Avatar
Does 4x4 work correctlly? Does heater doors change correctlly? does speed control work? If these are happening in addition to blowby you might suspect the vacuum pump has become a air compressor for crankcase. Check hose from pump to cowl and across cowl. There are fittings that detoriate over time or get damaged.
Old Jun 20, 2010 | 07:36 PM
Redliner's Avatar
Yeah everything is working ok inside as far as i can tell.
jeepullr
Feb 22, 2007 07:43 PM
AVMech
Apr 2, 2006 01:43 PM
Neil58
Feb 25, 2006 12:23 PM
mcevins
May 18, 2004 07:24 PM
