Blow by bottle ?
Old Jul 22, 2004 | 10:06 PM
s cesnick's Avatar
Unhappy Blow by bottle ?
I recently bought an 01' 2500 and noticed alot of oil sprayed on the underside of the motor, mostly drivers side.. I researched this site to try and find the exact location of the blow by bottle/ I put it on a lift at work and I followed the vent tube the oil looks to be coming out of up to a thing that actually looks more like a hockey puck than a bottle. Is this the bottle? if not where is it ? If you have'nt guessed by now I am not a diesel mechanic. dirt bikes , yes , diesels no. too many parts.. thanks
Old Jul 22, 2004 | 10:12 PM
Mechanos's Avatar
The bottle is on the end of the vent tube and looks like... well... a bottle. If you don't see it and only see the bare end of the vent tube, the previous owner has likely removed the bottle.
Old Jul 22, 2004 | 10:21 PM
fschiola's Avatar
If you find that the previous owner removed it, you might want to add a 3/4" barbed plastic fitting and a piece of 3/4" heater hose to lengthen and route it below the engine to eliminate the mess you're getting.
Old Jul 23, 2004 | 12:36 PM
TXRAM2's Avatar
The hockey puck you describe is where the hose connects to the engine. If there is no bottle on the other (lower ) end of the hose, then likely it has been removed. Route the hose down to the under side of the engine, and it will save you from having a mess in a almost impossible spot to clean.
hth
wayne
Old Jul 23, 2004 | 01:11 PM
Moose10's Avatar
I used exactly 3' of hose, and ran it straight down in between the axle and trac bar. It hangs down far enough but not too far.
I would suggest to check your radiator fins too...they're probably coated with scum that has stuck to the oil mist being pulled through by the fan.
My rad is coming out of the truck for a good cleaning when I do the 45k mile service. Then there should be no more future problems.
Some screen behind the grill helps too.
Old Jul 23, 2004 | 01:52 PM
s cesnick's Avatar
Hey, thanks guys. I was worried that I had a major problem. I kinda figured that the bottle was just removed but had to be sure.. Thanks again..
pipergsd
Feb 9, 2007 04:28 AM
MadDog01
Oct 16, 2005 05:44 PM
rementa
Mar 8, 2005 12:37 PM
Dr. Evil
Jun 28, 2004 05:50 PM
latitud_rt
Jan 1, 2003 12:41 PM
