block heater
Old Nov 18, 2008 | 06:20 PM
benroberts3605's Avatar
block heater
it looks like there will be a chance that i will not be able to plug in at work so i was wanting to know what i should do about oil viscocity to compensate for not having a block heater.
Old Nov 18, 2008 | 06:48 PM
dozer12216's Avatar
There is 5-40 in synthetic form. A 0-40 is also avaliable. Next step is a 10-30 for extreme cold diesel.
In Southern Ohio, use a 5-40 and you will be fine. It is easy to find.
Old Nov 19, 2008 | 08:54 AM
drafalske's Avatar
"Southwest Ohio" as in Cincinnati area?
I live just south of the border in Kentucky. I run Rotella 15w40 year round without any problems. It never gets cold enough here to worry about changing back and forth. Might want to give it a minute of two after you start it to get the oil warmed up a little if you can't plug in.
Dave
Old Nov 22, 2008 | 06:44 PM
neveragain's Avatar
Block heaters
I always just have to change things! I have a 1400 Watt generator that will power the two battery warmers and the block heater, the trouble is that the fuel tank isn't big enough. So the other summer I drilled a hole into the fuel tank of a specific size that will fit an o-ringed fuel fitting with a stainless braided hose 3 ft long? with an drilled and tapped 1/4" piece of steel with a gas compatible gasket to a 20 L container. The one time when it was -30*C it ran for 6 hours and it didn't make much of a dint in the fuel. Where as with the factory tank it was empty in a short time. Where there is a will there is a way, and I will have my way!
Old Nov 22, 2008 | 07:16 PM
Tate's Avatar
Synthetic oil makes a big difference. Definitely cranks faster. If you're gonna be working in the cold with no plug ins, a coolant heater like an Espar/Webasto will be a great thing to have.
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
Reelay
Dec 1, 2005 06:14 PM
