best place/price for SBC?
Old Apr 9, 2007 | 10:53 PM
greenwing's Avatar
Where is the best place and price for a south bend clutch? I'm gonna be in the neighborhood for a new clutch soon and I guess I'll buy a South Bend since I've heard nothing but good about them. I don't really know what to think about LUK and don't really know of many others. Also, which would be the best for me? I don't just want a stock replacement, but on the other hand I don't want anything too extreme. I have a comp box now and would like to eventually put a set of semi-mild but not too wild injectors in and that's about it. Possibly slight turbo upgrade, though I doubt it. I may try a different chip but nothing different power wise.
Thanks,
-Ryan
Old Apr 9, 2007 | 11:04 PM
dodgezilla04's Avatar
call lary at the dtr store. he can get them for a good price and the proceeds go to the site.
Old Apr 9, 2007 | 11:06 PM
Tate's Avatar
Depends on your location. Usually, the close the better. I dealt with Piers, since I wouldn't have to deal with currency exchange, or border issues. PDW is good from what I hear, although I haven't dealt with them personally. You could also look into Valair clutches. They are getting a strong following on here, are cheaper than the SBC's, and still have great customer service. You should talk to the manufactures, or vendors of these clutches. They will help you pick the one that suits you best. Just be honest with them. But as a guess, I'm gonna say a Con OFE would be a good choice for your, if you do stay fairly mild. But everyone says that at first.
greenwing's Avatar
Looking like probably the con-ofe?? and what does the non-ETH mean?
Old Apr 9, 2007 | 11:08 PM
Tate's Avatar
ETH is the high output, has the 13" clutch. ETC is the standard output engines, has the smaller 12-1/4" flywheel. Most of the clutch upgrades use the bigger flywheel. If you have an HO, you can just order the disc and pressure plate, otherwise you get a new flywheel too.
Old Apr 10, 2007 | 06:55 PM
greenwing's Avatar
I am wondering if a con O would suffice? I will always have a comp box or something comperable and maybe get rv275's or maybe a hair bigger but not more than 75hp injectors. Probably RV's just due to the price.
What do you guys think??
Old Apr 10, 2007 | 07:02 PM
Captain's Avatar
I agree. Get it from the DTR store. Best price you'll get anywhere and it helps the website out. Also I'd never get anything less then an OFE. price isnt really much differnt. Its still very very driveable and you wont regret it later if you decide to up the power a bit.
Old Apr 10, 2007 | 07:44 PM
greenwing's Avatar
I called and I assume it's too late in the evening for anyone to be in the DTR store but I did leave a message so we'll see what happens. Thanks guys!
Old Apr 10, 2007 | 09:44 PM
J Lent's Avatar
I just learned the hard way about a LUK clutch.....it was so grabby that it blew the springs out the disc. Go Southbend & be done with it. A few months ago I would have recommended the LUK, but after only getting 30k-40k miles on it.....never again.
Old Apr 10, 2007 | 10:05 PM
greenwing's Avatar
Yeah... I'm definitely gonna go SBC! Just gotta decide which one?
Old Apr 11, 2007 | 10:52 PM
Sixpack's Avatar
I have the Con-O. I like it but I can slip it if I run it hard with the rpm's low. IF you don't have the vp's wire tapped for the comp, and don't plan to, the Con-O will work fine for you. It did for me until I added the Mach 1.6's. I'm now right at the limit for this clutch. I wish I would have done the Con-OFE.
Phil
Old Apr 11, 2007 | 11:10 PM
J Lent's Avatar
What are your plans for the truck? Do you tow? HP goals are also a big question here. Then call Peter at SB & he will answer all of your questions.
Old Apr 11, 2007 | 11:46 PM
just go with the ofe. it will give you some room to grow. you dont want to spend the money and time and realize you are over the expected limits of your new clutch.
Old Apr 12, 2007 | 05:24 AM
greenwing's Avatar
Agreed! Thanks guys!
texaspower19
Apr 28, 2006 05:39 PM
txdodge97
Mar 15, 2006 12:31 AM
mopar2ya
Nov 19, 2004 01:25 PM
1320
Jun 1, 2003 11:41 AM
