Battery Question
Old Sep 25, 2009 | 09:28 PM
ebteckx's Avatar
Battery Question
Hey guys I am in need of your help. I am working on my friends 2002 24v. Its been a while since I owned my 24v that I dont remember if there is a special procedure for changing the dual batteries. I am installing 2 new optimas and I just flat out dont remember. Any info would be helpful thanks guys!!!
Old Sep 25, 2009 | 09:38 PM
BigIron70's Avatar
Cummins Guru
Always remove the negative cable first on both batteries. If you don't you run the risk of shorting the connection with your wrench. When installing new battery always install positive connection first. Use a battery terminal cleaner and a battery sealer to stop battery terminal corrosion. 750 CCA battery for diesels works best.
Old Sep 25, 2009 | 09:48 PM
RowJ's Avatar
Never used them. Think the Optimas don't fit quite right.
Group 34/78 Optimas fit OK and you might be able to make a Group 65 fit (these are used in the third gens I believe).
You can make all sizes of batteries fit if you cut out one side of your battery tray.
RJ
Old Sep 25, 2009 | 11:00 PM
dozer12216's Avatar
You may charge both batteries together but better to charge before installing.
Old Sep 26, 2009 | 06:41 AM
ebteckx's Avatar
Ok thanks guys. I just wasnt sure if there was a procedure for which battery to unhook first or if there was a special order to avoid shocking the computer. I appreciate the response!!!
Old Sep 26, 2009 | 07:35 AM
John Faughn's Avatar
You do not need to charge new batteries .
If for some reason you need to charge any battery bank [ no matter what size , a battery bank is just a group of cells , 12v auto , are 6 cells , 6v is 3 cells , a room of batteries for a solar system / what ever ] is a bank , any battery bank should be charged just as there used , connected together , if they are charged separately they can be unequal , charging together will equalize them .
Again if for some reason you need to charge the batteries in the truck , just hook the charger up to one battery & charge [ assuming all connections are good ] , just keep the charging current under 150 amps , the alt. has the ability to put out at least 120 amps , so you not going to do anything to the system that does not happen during normal driving .
Rancher99
Apr 18, 2011 09:46 AM
jesussaves
Nov 7, 2010 06:55 AM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
