batteries and starter
Old Sep 14, 2009 | 10:04 PM
deaconn's Avatar
hey is there a fuse in the line somewhere between the ignition switch and the battery . i've done everything i could new starter new batteries new ignition switch and still can't get the thing to start at the wheel i can jump it from the starter any ideal's. and this is probaly related in some way but my batteries keep dying even though nothing is on maybe dying isn't the right word but they are to low to start it so i have to charge them every 5 times i start it . could this be from jumping it at the starter?.
Old Sep 15, 2009 | 12:58 AM
nickg's Avatar
safety neutral switch (if auto) not sure if standards have a clutch switch or not.
Have you checked your alternator output? maybe you dont have a parasitic drain as much as the alt is not charging.
when you turn the ignition check at the small wire on the starter it should light up when you check it with a test light, if it does not work your way backwards to the ign switch,
Do you have a wiring schematic?
Old Sep 15, 2009 | 03:07 AM
dozer12216's Avatar
You might check fuses. The big fuse from alternator. And a little fuse for starter relay. Both in power distrubution center, left side of engine compartment.
Old Sep 15, 2009 | 09:47 PM
deaconn's Avatar
i'll try and will see thx.
Old Mar 8, 2010 | 09:01 PM
flimmy's Avatar
deaconn , did you ever get this problem fixed ? What did it turn out to be ?
waltlarson
Apr 17, 2011 08:34 AM
FMB
Nov 14, 2010 09:09 PM
buckman361
Nov 13, 2008 09:54 AM
CrashCade
15
Jul 22, 2007 11:51 AM
Paradise Racing
Jan 18, 2005 09:08 AM
