Ball Joints Complete?
OK the ball joints were finished yesterday easy job NOT!! So I top off the front diff with fluid because it leaked alot out well I topped it off maybe a little full. Now today after driving around I have fluid coming out of both sides of the axle tubes???? hmmmm goood or bad or did i just over fill the the diff???
thanks for all the input guys, I was kinda figuring all this was possible. It sucks cause i have oil splash every where now. I parked it in the driveway with the front facing down the drive so it would all leak out, this morning i had a quarter size drip on the pass side and drivers side had about the size of a credit card. Im heading to the Darlington race today Im taking xtra fluid with me just in case. Oh and i have an xtra ticket too.
I think the level is susposed to be 3/4 from the fill hole, it is possible to damage the seals if you were not careful when sliding the axels in
I've done lots of BJ/U-joints and have never noticed any oil leak out of the tubes! maybe you were over full to begin with
it did leak alot out when i was doing the change and i refilled it but i know for sure i over filled because it was coming back out the fill hole. I was very carefull in reinstalling the shafts just due to the seals, the leak is not as bad today when i got to work it wasnt dripping so hopefully nothings damaged
I usually give the end of the axle shaft a good coating of grease before I slide it back in to help prevent seal damage. I have only ruined 1 seal from not being careful on sliding it back in.. That truck had over 400,000 miles on it..
firebill1720
20
Mar 5, 2010 09:23 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
