axle hop?
axle hop?
When I have my truck in 4 wheel drive and it starts spinning, (mud, or snow) the axles start hopping. Could this be bad shocks. It will shake the truck something terrible. Thanks.
sorry to change the thread a little bit but if im in 4wd and its not snow or mud my truck hopps only when im turning its wierd when im going strait theres no prob but when i am turning it bucks a lot
and the truck will "hop" if your on the throttle as traction conditions change, this too is normal. remember the TC divides the same power between both diffs and if traction is different at each axel they end up "fighting" each other causing the hop (or axel wrap), as something has to give....or break
Powermad, Thats the drive train fighting its self. It is totally normal not the most healthy but, thats why you r only suposed to use it in slippery conditions. When going striaght all the wheels are traveling the same distance but, when turning you have tires turning traveling shorter distance and longer causing it to bind up. Its kind of like a full posi rear end the inner tire is going to want to turn faster than the outer tire causing the tires to bark or wheel hop because something has to give.
This is a good thing to know when test driving a 4x4. Both two jeeps that I test drove had no 4x4 whatsoever. The funny thing is the owners act like they are gutshot
and or I'm nuts when I tell them the 4x4 doesn't work. I bought the second one after finding the vac leak. I'll install a posi lok here shortly and be down the road..
If your truck doesn't do this, start looking for the problem.
Jeep has a few transfer cases that have a viscous coupling in the tranfer case so you don't have binding on dry pavement.Just a heads up
Bob
The Jeeps I was refering to were mid 90's Wranglers or YJ's. Thanks for the info.
Uncle Red
Mar 4, 2006 01:51 PM
xj2extreme
Feb 20, 2003 10:38 PM
