Auto Transmisson
Old Oct 15, 2009 | 07:14 PM
jayhawk310's Avatar
Unhappy Auto Transmisson
01 Dodge 2500 CTD truck won't shift out of low gear unless you let up on the foot feed, then it will shift onto the rest of the gears. I had trouble one time getting it to go into park. It shifted fine before today. Thanks
Old Oct 15, 2009 | 07:36 PM
77machomopar's Avatar
sounds like linkages and or tv cable
Old Oct 16, 2009 | 11:14 AM
sheriffav8r's Avatar
Check your fluid level, too. Do a search on the proper procedure....
Old Oct 16, 2009 | 11:30 AM
RowJ's Avatar
If your saying won't shift out of 1st, with lever in drive, then....
My guess is Governor Solenoid ..... or Transducer (pressure sensor).
Bad news - The factory parts tend to fail after 100,000 or so.
Good News - These two parts are not expensive (by Dodge standards).... AND are easy to replace at home.
Both parts are on the bottom right (passenger) side of the valve body and only require a small socket set and a T25 Torx bit.
I've seen Governor Soleniods never downshift to first.... or not shift out of a gear (usually 2nd)without releasing pressure, like you mention above.
Trouble with lever going into park... or with tranny shifting into park after the lever reads 'P'??
That sounds like linkage.
RJ
Old Oct 17, 2009 | 08:37 AM
jayhawk310's Avatar
Smile Problem fixed
The clamp that holds the second gear band broke and got into the park linkage. Repaired and serviced and everything is working again.
streetdoc
Apr 19, 2015 09:31 AM
jerry007
Jun 17, 2006 11:46 AM
Darren srq
Feb 20, 2006 11:12 PM
Truckracer
Apr 4, 2004 08:31 AM
