auto trans temp
Old Sep 14, 2008 | 10:20 PM
bigsmokey's Avatar
auto trans temp
I have been keeping an eye on my tranny temp to see if the tranny is starting to slip do to power upgrades and i was wondering what kind of temps you see how high is to high.
Old Sep 15, 2008 | 08:07 AM
sheriffav8r's Avatar
I see about 150 doing 70-75mph no towing.
Old Sep 15, 2008 | 08:42 AM
high bid's Avatar
towing approx 5k lbs I see about 180-190 on a 95deg day.
Old Sep 15, 2008 | 09:44 AM
RowJ's Avatar
Depends where you live (not given) and your outside temps on what you will see. Rule of thumb....empty at 70 mph criuse.... temps from 140 - 180 are in the ok range. My built tranny will cruise all day at 140*, in clear air, on a 90*+ day. Pull in behind an 18 wheeler and watch the needle climb!
Stock tranny slippage from to much HP will show up as increase in rpm's with no noticable increase in speed. You should feel it if looking for it.
RJ
Old Sep 15, 2008 | 02:55 PM
smokinram99's Avatar
I recently installed a recon xzt gauge on mine and see 150 or more in town and 130 on the highway(55 mph) with an outside temp of 65F... 130F is too low?
rob
Old Sep 15, 2008 | 03:13 PM
RowJ's Avatar
Not at 65*F.
Within reason... impossible to be too low!
I've read about Canadians that have 150 - 400* gauges that register NO tranny temp..... all winter!
RJ
Old Sep 15, 2008 | 03:29 PM
here is 20°C degrees(celsius) last night... 20C are 65/70F exactly?
recon reads 128/130 at 90kmh (about 55mph)
my truck is Canadian, yes
Old Sep 15, 2008 | 04:00 PM
also my recon read 100 when I start the truck after a day in the garage..!
I haven't 100F (37C degrees!!!) in my garage!!
Old Sep 16, 2008 | 07:18 AM
Your gauge doesn't register below 100F. Once your tranny gets warmed up it will start to register on the gauge. In town driving will produce higher temps than normal cruise on the highway because you are working the auto more. Worry about the high temps, not any low ones....
Old Sep 16, 2008 | 10:24 AM
dozer12216's Avatar
Temp is not best indicator of slip in clutches. U can feel em slipping. The life expecanty of slippping clutch is seconds under full load. If engine RPM is not arrested after shift it's slippppping. If rpm increases unaccountablly it's slippppppppping. Get the ideal!!!! The tranny fluild will get a ugly dark to black look and smell like smoke. Then it quits pulling or pulls all the time depending wheter the clutch pack welded itself together or not.
Old Sep 16, 2008 | 01:43 PM
j-fox's Avatar
Also it is very important to read the temp in the out line to the coolers.
The next best is in the pan.
If you are reading it at the test port that some recommend, you are only reading the case temp!!!!
Old Sep 16, 2008 | 01:56 PM
I've installed the probe on the test port on the passenger side of tranny, like recon instruction tells... I'll get a fitting for the cooler lines next..
why it's impossible 130F at highway speed? (with outside temp of 65F or little less)
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
Lenn
Jul 23, 2004 09:44 AM
MrDiesel
Jan 6, 2003 09:00 PM
