APPS Reset Question
Old Jul 2, 2008 | 12:11 PM
Tyheethan's Avatar
APPS Reset Question
If I am having no problems other than mileage that I think is too low, 14.5 around town, is there any harm in doing an APPS reset? This is the 2001 in my signature. It has about 115k on it now, and I have had it for about 30k of that and since I have had it, the APPS reset has never been done. Retired guy who made no mods had it before I did and I doubt he ever did anything like that either.
Any thoughts?
Old Jul 2, 2008 | 01:30 PM
R.T.D.H.S.P.'s Avatar
Go for it. And while you are at it, you may want to clean your IAT sensor. Often times this increases milage as well.
Old Jul 2, 2008 | 10:52 PM
Tyheethan's Avatar
So it does not appear that resetting the apps could do anything but help what ever issues I may/may not be having. I just want to make sure I am not doing something that will cause me a problem considering I am towing my RV about 300 miles on Friday.
Old Jul 3, 2008 | 05:05 AM
crobtex's Avatar
Doing the APPS reset will hurt nothing. If you do the re-cal, just be sure you're careful and do it right.
Old Jul 3, 2008 | 11:00 AM
Tyheethan's Avatar
Sorry for so many questions--I just want to do things right. What is the difference between the APPS reset and the re-cal that is mentioned?
Anyhow, this is the procedure for the APPS reset that I found that I plan to follow.
This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration, improper shifting, bucking in 5 and 6 speeds. Has been known to increase fuel mileage in some instances.
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
Thanks for the help!
Old Jul 3, 2008 | 11:14 AM
crobtex's Avatar
Sounds right to me.
clarson80
17
Sep 22, 2007 09:17 AM
supr
18
May 21, 2007 09:29 AM
1882
Sep 22, 2006 07:08 PM
PDXDodge
Jun 2, 2005 02:58 PM
MoreSmoke
Feb 14, 2004 08:51 PM
