APPS or injector pump?
Old Jan 17, 2010 | 08:34 PM
noisy 01's Avatar
I have had this ongoing problem for 6 years on my 2001 dodge diesel 5 speed and I need your help.
The fuel pedal dissapears and you go nowhere,then take it out of gear and idle for 10 seconds and then you have power again or shut it off and restart it and it will make power again.
Just when I think I've figured out the pattern of this problem it falls on it's face again and you have the feul pedal that doesn't seem to be connected to anything. every mechanic tells me to thow a $2000 pump at it but I have a hard time believing it's a pump when it runs flawless some days?
tell me what you think. THANKS GUYS
Old Jan 17, 2010 | 08:49 PM
Dieselbuilder's Avatar
pump
Old Jan 17, 2010 | 09:24 PM
johnh's Avatar
any codes??
Old Jan 18, 2010 | 06:04 AM
noisy 01's Avatar
ongoing missing fuel pedal
no codes or check engine light ,and if you try to let it warm up LOTS of blue smoke and popping. THANKS AGAIN
Old Jan 18, 2010 | 07:48 AM
nickg's Avatar
read this
http://www.bluechipdiesel.com/vp44diagnostichelp.html
more than likely its a pump, as 99.99% of the time an APPS sets a code (some have reported a bad apps and no codes)
Old Jan 18, 2010 | 09:35 AM
johnh's Avatar
before changing vp, check all connections on all sensors and vp 44, maybe you'll get lucky
Michigan Ram
17
Mar 10, 2016 11:51 PM
gablekevin
Sep 19, 2006 12:12 AM
billygoat02
Dec 29, 2005 11:03 PM
calls
38
Jun 6, 2005 06:08 PM
