Any ideas
Old Mar 15, 2016 | 06:07 PM
turbox2's Avatar
Any ideas
New ecm new crank sensor new cam sensor but still telling me I need a cam sensor this all started with no start. I have my priming pump on a switch not hooked to pcm is this my problem?
Old Mar 15, 2016 | 07:39 PM
jrs_dodge_diesel's Avatar
None of the sensors have anything to do with a no start condition.
The only thing needed at startup is 12 Volts and sufficient cranking speed. The VP44 runs alone during startup. After startup the ECM brings the sensors online and works together with the VP44 to control the engine.
Lift pump is controlled by the ECM, not the PCM.
Need to have more information to help with your problem. Any odd engine behavior before your problem started? Fuel pressure? Any codes or check engine lights?
Old Mar 15, 2016 | 07:41 PM
Wait a minute, just read your signature, are the problems your having on your 96 Ram? If so then you very likely have the 12 Valve engine, and not the 24 Valve (electronic) engine that came out mid year in 1998.
If you have the 12 Valve engine, I'll move your post over to the 12 Valve forum.
Old Mar 16, 2016 | 07:21 AM
turbox2's Avatar
no working on 99 the ecm was bad no start replaced it runs sorta misses at times no tach all other gauges ok gave code for bad crank sensor put in new one now gave code for bad cam sensor put in new one.Still no tach and still giving me code for bad cam sensor the pick up pump is wired to a switch by its self
Old Mar 16, 2016 | 02:57 PM
SIXSLUG's Avatar
I'd start by checking and cleaning every ground wire you can find....cheap and free
Old Mar 19, 2016 | 09:31 AM
turbox2's Avatar
All grounds clean still same problem still lookn
Old Mar 20, 2016 | 10:44 AM
KATOOM's Avatar
Yes, a bad CPS will cause a no start and random hard start condition.
Old Mar 20, 2016 | 12:14 PM
torquefan's Avatar
Check the tip of your crank sensor for physical damage. There have been cases on the 24 valves where the tone wheel has come loose from the crankshaft and damaged the crank sensor. Could explain why you would have the same trouble with a replacement sensor.
Old Mar 20, 2016 | 04:01 PM
patdaly's Avatar
^^^^ This, happens more than people think.
Old Mar 20, 2016 | 09:17 PM
In the Caterpillar engine world, we call them magnetic pickups (mag pickup for short). Some of the larger engines get several of these sensors. One difference with them is that the Caterpillar sensors are adjustable, they are threaded and have a lock nut to hold them in place.
I have seen more than one of these with the tips destroyed. Once because a tech didn't adjust it properly and it was too close to the flywheel teeth. That one made a funny noise when they tried to start the engine, a 3508 genset.
Sometimes a metal chip can get stuck to the end and cause interference as well.
Old Mar 21, 2016 | 03:16 PM
turbox2's Avatar
old crank sensor shows no damage I have replaced the cam sensor p341 code but it still tells me the cam sensor is bad still no tach.when I clear the code and start it it runs 20 sec with tach working ruff engine light comes on loose tach runs smooth crap This is driving me nuts I have worked on all kinds of diesels this one is getting to me guys
Old Mar 21, 2016 | 04:46 PM
AlpineRAM's Avatar
Some interesting things can be found at
https://www.dieseltruckresource.com/...sensor-259265/
Basically the same reasoning on the 5V supply circuits and the connectors could maybe worth pursuing.
I had a lot of equipment with erratic trouble codes where almost everything had been changed and all was caused by sensor supply getting shorted to ground or shorted to signal.
Old Mar 21, 2016 | 08:24 PM
turbox2's Avatar
I will check for shorted wires that are messing with 5v signals thanks
Old Mar 24, 2016 | 11:43 AM
Get a multimeter and check for proper voltage at the sensor connections. Should be +5 Volts. Had a case recently where a member here had a sensor that shorted out and disabled several other sensors since they couldn't get power. Once he found and replaced the bad sensor, everything worked correctly again.
Old Mar 25, 2016 | 07:06 PM
SIXSLUG's Avatar
I was starting to think that^^^ bad wire/connection etc. Chase down with multi meter.
