any body no why my truck has these codes!!!
Old Dec 4, 2011 | 04:01 PM
arren333's Avatar
p1693 p0382 p1763 p0713 p1765 p0753 if any one can help or no how to fix it thanks!
Old Dec 4, 2011 | 10:50 PM
KATOOM's Avatar
I dont know what they all mean since I dont have a full code list but it sounds like you have an electrical issue. Have you properly checked your batteries for condition, battery cables, and if you live in a high corrosion area, check your grounds. Proper way to check batteries is to remove them from the vehicle and have them interdependently load tested to see if there's any cell problems since with more than one battery, a bad battery will be masked by a good battery. Understand that the ISB Cummins is fully electronically controlled and if you have any battery condition issues with voltage/amperage then you can experience many strange issues causing you to chase your tail.
Old Dec 5, 2011 | 08:26 AM
rebal's Avatar
are you experiancing transmission issues? check the body ground from the right side battery to fender also make sure your battery connections are CLEAN and tight. like was stated before if your batteries are filthy it can make your life difficult
Old Dec 5, 2011 | 11:35 AM
SIXSLUG's Avatar
1693 DTC detected in Companion Module: Usually always throws with another code.
0382 Intake air heater relay #2 control circuit
1763 Governor pressure sensor volts too high
0713 Trans temp sensor Voltage too high
1765 Trans 12 volt supply relay CTRL circuit
0753 Trans 3-4 shift solenoid/trans relay circuits.
Sounds like the above suggestions are a good place to start. Clean all your grounds after you get the batteries checked.
sgrooms
21
Apr 8, 2008 11:17 AM
bway1341
Jun 7, 2007 06:23 AM
fullbore farmer
Apr 9, 2007 08:49 PM
