Another one bites the dust
Old Nov 26, 2007 | 09:39 PM
diesel_burner's Avatar
Well, looks like I get to be the in the VP-44 club. Truck took a dump on me on my way to my parents for t-giving. I made it all the way but the root cause was a failed FASS pump. I guess it stopped working and then no fuel = no VP-44. But the FASS was only 6 months old so warranty. But no luck with the VP-44. 107xxx miles. But I guess I'll have them flush the coolant and power steering fluid well it's in there. I'll let you guys and gals know what the bill is when I get it. That way you can tell me if I'm getting the high hard one or not.
DB
Old Nov 27, 2007 | 04:56 AM
wurkenman's Avatar
Just so you know, your pump (if it has not been tampered with) is still under the factory warranty. The Cummins diesel engine is warranted for a period of 5 years or 100k and goes into effect AFTER the Dodge basic 3/36. It in you factory warranty book. The dealer will fight you on this. I got the 800 number for DC and called after I paid for my replacement and got a check back -100 for the deductible.
Old Nov 27, 2007 | 08:23 AM
Mule Skinner's Avatar
Wurkenman, do you know if that warranty covers water pump and t-stat, dealer told me the 5 years was passed so I pay. Maybe worth looking into if the 3/36 applies and warranty covers those items.
Old Nov 27, 2007 | 06:58 PM
MikeyM's Avatar
That sucks dude, sorry to hear it. Did you have the little filter installed before the FASS? Just curious as I have one of their HPFP 95 units and was about to install it. These posts always make me second guess my decision but I suppose it's better than the OEM pump as long as you have some way to monitor fuel pressure.
Thanks, Mike.
Old Nov 27, 2007 | 07:36 PM
wurkenman's Avatar
Look in your warranty book or search this site. The book states and is very specific on what is covered and what is not, but I know for a fact that the VP, lift pump etc are covered. I know it sucks, but I had to pay the bill and then do the footwork to get my refund. Still the bill was 2300 installed at the dealer.
Old Nov 27, 2007 | 07:56 PM
fordkiller43's Avatar
I have been told that the VP44 and lift pump and covered up to 5 year 100,000 miles as well. Good luck bud
Old Nov 28, 2007 | 01:13 PM
Thanks, Mike.
No I have a Ramco filter before the Fass. It's a 5 micron filter. Yeah it is weird, they say those things are supposed to last to 30 years or something like that. I'm sure they will want to see what the default with it was because it is only 6 months old. I wouldn't worry to much about it. It's just one of those crappy deals.
Old Nov 28, 2007 | 04:38 PM
Moose10's Avatar
burner, how old was your FASS pump? What about the warranty on that?
Old Nov 28, 2007 | 05:01 PM
blizz's Avatar
Did you have a FP gage, if not you need one... fass or carter i keep a extra one under the seat .
Old Nov 29, 2007 | 12:40 PM
Moose, the pump was only 6 months old and is getting the warranty.
Yeah I have an FP gauge, everything was working fine, just one of those things i guess. Not to worried about it. I figured the vp44 was on the rocks for the last 25000 miles. I was just hoping that it would make it past 100K because I tapped the wire at 50k.
Old Nov 30, 2007 | 09:30 AM
Diesel-Dan's Avatar
If this is a HPFP......you WILL have fuel pressure issues with a filter that tight. You need to use a NAPA 3270 144um micron STRAINER. 5um is WAY too tight to be on the suction side of any pump. This needs to be on the pressure side. Just letting you know.....to keep all this from happening again......
Old Nov 30, 2007 | 11:14 PM
Do you think that is what killed the FASS? Will the Napa fit on the set up I have? That would be the best fix or I could just switch the lines around. But anyway let me know what you think. I didn't even think that could have been the cause, that has got me going a little bit right now. Thanks for the Info.
rharveysr
Sep 24, 2005 01:48 PM
runamuk
Jul 12, 2005 12:23 AM
BigBlue
Nov 3, 2004 11:00 AM
J BODY
Sep 7, 2004 10:55 PM
Tengu
Jun 19, 2004 09:43 AM
