Another Noobie Question about engine warm up
I read in the owners manual about warmup time versus full load operation, but what is a good rule of thumb. I have been cranking my CTD this week (40F outside temp) backing down the driveway to keep from waking up the baby and then slowly easing out of the driveway and down the road at less than 40 mph. Is this OK or should I sit in the driveway for a while and let the engine warmup? Want to keep the truck a long time.<br><br>Thanks
Re:Another Noobie Question about engine warm up
Your not supposed to idle for a long time with these engines. At 40°, I think your fine doing what you do. I normally plug in every night, but if I don't, I only idle for maybe a minute or so revving the RPM's up at about 1200 and then just take off. Just keep it easy for the first couple miles until the engine temp get's up. You'll be fine!<br><br>Welcome to the site! ;D<br><br><br>Tony
at 40 degrees just start and go .........that's not even cold<br><br>at -40 I let it run at least untill it's firing on a ll 6 cylinders first before I take off
<br><br>
<br><br>
Well guys, what about this. It seems to me the engine is a little noisier when cold and not as powerful. It also seems to take several miles before I see any change in the temp gauge. Is this normal for the CTD?
Is it Auto or Manual? <br><br>On my Auto, I keep my OD locked out until i'm at about 45-50mph -- keeps the RPMs up higher and seems to warm up alot faster...
I let the oil pressure come all the way up and idle down the driveway. When the temp needle starts climbing I drive it like I stole it! ;D ;D Don't be too heavy on the go pedal until the temp starts to come up though.
[quote author=TPilaske link=board=4;threadid=11014;start=0#105132 date=1045351380]
[/quote]
My truck does this on its own anyway. I plug mine in, should I let it warm up for a min. or two or just wait till the oil pressure come up (that is what I do now).
KC
[/quote]
KC
mtb1982
55
Jan 20, 2020 10:45 AM
CanuckRam
May 29, 2006 12:32 PM
