Another Dodge 5.9 Issue
I have been reading a lot of the posts on ECM issues with the 1999 Dodge 5.9L Diesel. I am looking for a clue as to this new problem to add to the mix.
I had a short in my drivers seat that killed my battery causing me to disconnect the battery and charge them from time to time. Every now and then when I disconnected the battery and reconnected it I my truck would not start. No Fuel pump etc. I checked the fuses and relay to the fuel pump and found no power there, however at times when I probed it with my meter, It would activate the ECM.
Does that mean that I have a bad ECM? I checked the grounds and as many connectors that I could find. I am just not sure. I do not want to purchase an ECM and have the same problem.
Sounds like you are back powering the ecm thru a hot lead wire. I think the seat power is on a relay. That may be a good place to start. I am on my second ecm and at about 80K since the new one....not sure the ecm has anything to do with the accessories though....any aftermarket goodies or backyard electrician items??
dan123dbl
Feb 13, 2015 05:47 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
